unofficialy slowest ls1
ive only ran my car three times at the track and got a 13.9 and this is at "the worlds fastest track" darlington i have lid,filter,bellow,maf,no cats,hooker lts, flowmastermuffler,10mm wires,tr6, with nitrous got a 13.1 this is a 2002 ws6 the collector edition a4 from the times i see from you guys something is wrong with my car i know i have a little weight from the stereo system but the only other thing i can think is i dont have the o2 simulators on the back spots yet from installing the lts could someone maybe give me an idea what is going on
Re: unofficialy slowest ls1
The MAF may be causing trouble, Flowmasters aren't so great, extra weight doesn't help.
Autotap data would help.
Gives us all of the slip data.
yeah im pretty sure im hooking i got the stock f1 but i hook on the street so i know i can on the track here is times
motor nitrous
60= 2.170 2.163
330=5.967 5.810
1/8= 9.040 8.657
1000=11.665 11.096
1/4=13.918 13.144
mph=99.48 110.25
and yeah the ce is yellow yeah i also that about the maf no idea what the car weighs but the weather was bad that day heat and everything but i thought it would still run better than that and thanks for the help
motor nitrous
60= 2.170 2.163
330=5.967 5.810
1/8= 9.040 8.657
1000=11.665 11.096
1/4=13.918 13.144
mph=99.48 110.25
Always run stock MAF ESPECIALLY with nitrous... Descreening the stock MAF is fine.
I would get rid of that flowmaster muffler and put in a dynomax ultraflo. (1000cfm for the 3 inch)
Good luck,
Chris
Good luck,
Chris
just got the gears havent had money for the converter yet and since i dont have the o2 simulators i didnt see any point in getting it tuned right now also just wanted to make sure that pulling the screen will still be good enough going through the air filter that nothing will flow into the motor
damn bro i think u might be having some tuning issues...you should be seeing a high 12 with that setup(off the bottle)...ur 60' could be better...
...ur MPH is way low...i say ur A/F ratio might be causing this, go get it tuned!
I wonder if he is hitting the 5500 RPM fuel pressure drop that alot of LS1's seem to have. Mine used to feel like I was hitting a 100mph headwind at 5500 RPM. Not all cars have this problem, from what I hear.
Oh yeah, and his 60ft times are horrendous.
"just got the gears havent had money for the converter yet and since i dont have the o2 simulators"
I'm talking about a TQ converter (it transfers the power from you engine to your A4 transmission.) A TQ converter is a FAR more effective mod than gears. Waaaaaaaaaaaay better bang for the buck. O2 sims have nothing to do with a TQ converter. You're thinking about the catalylic (sp?) converters.
no i knew what you were saying. yeah i know what the tc is. i was just saying i didnt have the gears when i was at the track and i was just saying the o2s probably have something to do with some messed up timing or tuning. sorry about that colonel
Lack of O2 simms will not cause a loss of performance in any way. That is a huge but very common misconception. The only thing not having O2 simms causes when you get rid of the cats, is an annoying check engine light in your face.
Do yourself a favor when you get some dough. Make a good converter and some Nitto drag radials your next mods.
His 2.1 second 60 foot times are better than mine. I spun to a 2.4 second 60 foot and still got a 13.3 at 107 on motor.
Something is not adding up........
