2001 z06 dyno results
Old 12-14-2008, 01:45 PM
85firebird's Avatar
Default 2001 z06 dyno results
My 01 z06 has Belanger LT's, catless corsa X, B&B PRTS, breathless performance CAI, i dynoed 367 HP 367 TQ, this was done on a dynojet.
Old 12-14-2008, 01:59 PM
RyderTA's Avatar
Not to shabby, is it tuned? I would've expected a little more with those mods, even with it being an 01. Now it's time for heads/cam!
Old 12-14-2008, 02:15 PM
85firebird's Avatar
It is tuned, before the tune the baseline was 357/357, i was expecting a little higher as well but as my tunner said thats good for an 01 considering 02-04s would be 20 more which would be 387 which is good for an 02-04Z
Old 12-14-2008, 04:25 PM
The Dragon's Avatar
That's the right numbers for the year and mods
Old 12-15-2008, 09:07 AM
registered user
ScreaminRedZ's Avatar
Looks like solid numbers to me! There's definitely a noticeable difference between the 01's and the 02-04's so I think the tuner is correct.
Old 12-15-2008, 10:09 AM
PewterScreaminMach's Avatar
Not bad. Now fix your sig pic so we can see it.
Old 12-15-2008, 05:39 PM
NVR KNO's Avatar
Nice numbers.... Have any stock numbers?
Old 12-15-2008, 08:44 PM
85firebird's Avatar
thanks, unfortuniatly i don't, the baseline with these mods before my tune was 357/358 so thats as close as i can get it. i have a torch red as well
Old 12-17-2008, 11:56 AM
NVR KNO's Avatar
Just wondering. I dynoed mine when it was stock and it put down 352rwhp/352rwtq.... On 2 different dynojets.
I have a set of Kooks LTs on the way and was just wondering what I could expect with the new mods....
Once again, nice numbers man.
Old 12-17-2008, 11:18 PM
85firebird's Avatar
Thanks! you must have a factory freak or the dynos were off, 02+ usually dyno that and if ur stock thats damn good!! way to go! with LT+tune you should see 20 more RWHP i would say. let me know when you get em on and dynoed!
Old 12-18-2008, 03:10 PM
kidcamaro98's Avatar
sounds about right...
I had a 01 LS6 long block put into my car...on the stock LS1 tune with intake/headers/exhaust and ported throttle body on a Dyna pack dyno (read 10% lower then a dyno jet I was told by the owner) without a Tune I made 351rwhp and 355rwtq.
so on a dyno jet I would be in the same ball park as you....a little higher if I got a dyno tune.
Old 12-18-2008, 03:30 PM
NVR KNO's Avatar
Well my first thoughts were that the dyno was off, but the same day a C6 Z06 dynoed within 15 min of me and he put down 443rwhp.... Which is the norm, so.... I would just have to say that its alil on the freak side.
I dont have any real track times with the car yet.... Only time I went with the car, the track temps were 168 degrees!!! It was the hottest day of the year at the track and everytime they tried spraying VHT on the track, all it did was make it worse....
Im hoping to make in the 380s with the LTs and a tune....
Old 12-18-2008, 07:51 PM
raptorws6's Avatar
Nice #'s.
Old 12-19-2008, 01:29 AM
98camaroLS1M6's Avatar
Nice!!
Old 12-19-2008, 04:29 AM
85firebird's Avatar
definitely let me know when you get it dynoed! iv also learned that wheels make a big difference in how much they weigh to power readings. Im not sure how much 18' CROME C5Z rims weight but i know the lightweight gunmetal ones that are optional would probably put more power down because they are extremely light, vs the heavier crome ones. This is just a guess im not sure how much it would effect but i know it does effect it.
I know some people go from a drag rim to street/show tires/rim and can loose 20hp on the dyno.
Old 12-19-2008, 08:09 AM
NVR KNO's Avatar
^^^^ I have the Black w/Chrome lip Z06 Motorsports.... 17s front and 18s rear. I would guess going from the gunmetal ones to chrome would only lose a few hp. My friend went from the stock 18s to some 20s and only lost 8rwhp, so....
Ill definitely keep you in check though....
Old 12-19-2008, 04:53 PM
85firebird's Avatar
yes please do, i have crome 18s in the rear, there was a post a week or so ago on the vette forums i believe and the guy went to 19 or 18' crome rims from lightweight carbon or polyurethane whatever the lightweight vette rims are, and lost 15 hp on the same dyno, his car was a cammed c5Z it was like 435 with lightweight rims and 420hp with the lighter weight rims.
Quick Reply: 2001 z06 dyno results
