How do you lock a 4l60E in 3rd on the dyno?
Old 01-03-2009, 07:44 PM
Pray's Avatar
Default How do you lock a 4l60E in 3rd on the dyno?
This is my second auto that I have tried to tune on the dyno to no avail. I can't get these things to stop down shifting to second. I tried leaning into it. I tried high rpms. Nothing works. The first car I did was a Corvette and now a TA. What is the deal? I manipulated every trans table I could find but that thing just keeps down shifting when you mat it.
Old 01-03-2009, 08:45 PM
02 BLK WS6's Avatar
I use HPTuners and log the pulls.
Old 01-03-2009, 08:58 PM
1bad lad's Avatar
when u are loggin there is controls with the logger u can manually lock up the converter also u can manually put it into third and it won't come out......
Old 01-03-2009, 09:08 PM
John02SS's Avatar
You can lock it in 3rd and lock the converter with the datalogger and you can set the downshift tables to 1 mph also in the tune. Hope that helps.
Old 01-03-2009, 09:34 PM
edcmat-l1's Avatar
Yep. Bi-directional controls.
Old 01-04-2009, 06:58 AM
Pray's Avatar
Ed/others. When you use the Bi-directional controls to lock third, can you still log the run? Some one else on efi live said that and being backed up by you and others on here is basically gospel. I am just not that familiar with the controler and I don't have the car in front of me to try this stuff out. I am assuming that I will start the data logger, get the car to speed on the dyno, then lock the trans in third, make the dyno pull, unlock the trans, then press the break button on the dyno? Thanks for the help guys. I should have clarified earlier that I am using Efi Live.
Old 01-04-2009, 09:43 AM
LS1Tech Sponsor
Slowhawk's Avatar
Bi-controls will do it BUT I've found some cars still won't lock under that.My personal car is getting a lockup switch to make it easier.
Old 01-04-2009, 10:50 AM
LSX Mechanic
Damian's Avatar
A Tech II will do it also.
Old 01-04-2009, 10:55 AM
moeZ28's Avatar
Put it in third, get up to 75mph, then start the dyno run...That always worked with my old car.
Old 01-04-2009, 12:54 PM
8 Sec Tuner
Mike TexaSS's Avatar
Hp Tuners or a tech 2.
Old 01-04-2009, 09:54 PM
Pray's Avatar
Don. Are you refering to the converter lock up, or locking the car in third?
Mike/Damian. I will check with the shop and see if they have a Tech II. I looked at HP tuners and it is just not for me. I am too far into EFI live now to change over.
Moe. Tried it and it didn't work.
Old 01-05-2009, 01:29 AM
got-a-ls1's Avatar
ye hp tuners under vcm controls in the scanner... you can select whatever gear you like and lock the converter. you can also add or remove timing without reflash and all kinds of other things like keep the fans on between each run. i love my hp tuners!
Old 01-05-2009, 02:21 AM
thunderstruck507's Avatar
hmm, I just put the shifter in 3rd on my car and nailed it...didn't downshift, but I didn't lock the converter
I think the snap on scanner i have has the ability to do that though, I just wasn't too worried about it
Old 01-05-2009, 06:25 PM
Pray's Avatar
EFI live has the same stuff. It is called Bi-directional or DVT.
Old 01-05-2009, 06:32 PM
Restricted User
1BAD_LS1's Avatar
put it in third run to about 70-75 mph....then mash it from there...did it that way today on my dyno runs and it worked fine.
Old 01-05-2009, 08:14 PM
venom ws7's Avatar
I dynoed lots of auto cars and I agree some replies take to 70mph+ then floor it
Old 01-05-2009, 09:21 PM
edcmat-l1's Avatar
I start pulls way lower than 70 mph. I like to start them as low as possible. Usually around 2 grand. Locked in 3rd, locked TCC.
Sometimes, if the motor is strong enough, or if the tranny is a little "iffy", it'll downshift, or blow through the TCC.. But, for the most part, once it's locked it's locked til you unlock it.
As mentioned before, the bi-di controls are great for locking in your timing, IAC, A/F etc. trying to figure out idle fluctuation etc. That and running the fans full blast between runs. Just open the bi-di controls, and start clickin around.
Same stuff EFIlive or HPT. Both will do almost the same things.
Old 01-05-2009, 09:36 PM
GMCtrk's Avatar
Ed,
Is it advisable to lock the converter on a stock 60e?
Old 01-05-2009, 09:52 PM
edcmat-l1's Avatar
Originally Posted by GMCtrk
Ed,
I do it all the time. I've hurt a few, but I don't think it was from locking them. They would probably be hurt just from dynoing them.
Usually if they won't hold, I'll stop tuning, just for fear of killing them.
Old 01-07-2009, 10:18 AM
12secSS's Avatar
If all else fails, change the calibration on the WOT TPS portions to not allow a dowshift. Then you can start your pull from 2000rpms in 3rd. That is what I do with some calibrations that do not respond to the bi-directional controls.
As for locking a stock 4L60E, it will not hurt it. Althought a stock converter's TCC lining will be damaged. I rarely ever see any gains worth writing home about, from locking a stock TC though.
Quick Reply: How do you lock a 4l60E in 3rd on the dyno?
