Baseline dyno, wow!
Baseline dyno, wow!
Hi everyone! This is my 1st post here.
A few weeks ago I bought my bro-in-law's 02 SS 6MT that was a bit on the neglected side. Been working almost every day on it since I got it bringing it up to its present state.
I did all the maintenance like the spark plugs (yes, I did all EIGHT of them... lost a pint of blood on the passenger side), fuel filter, Mobil1 fluids for all (engine, tranny, and diff. Will be upgraded to Amsoil on the tranny and diff in about 10k mi, Im using the Mobil1 just to flush it out because it seems that old fluid was the original crap), alignment, full detail job, real alarm, etc...
The car is all stock EXCEPT for the cleaned up the KnN air filter the previous owner had on it, and also did the free ram-air mod while I was at it, and a short-throw shifter (brand unknown to me).
Anywho, considering the present condition, I went into the dyno expecting 300-310whp. I was quite surprised when I saw...
Run#1- engine was not up to operating temp as of yet
Run#2- it was on it
Run#3- slightly lower #s and the apparent dip in ign timing at 4700 PROBABLY due to heat-soak
You guys are the experts here, Im the n00b. But from what I reckon, this is a pretty healthy setup so far! NOTICE- I set up the graph for SAE correction to be comparable to others here. STD cor run 2 had 333WHP/343WTQ.
Conditions- 81.25*F, 29.79 in-Hg, 49% humidity
I just wanted to baseline to make sure everything was good before continuing modding. I will not be touching the engine in quite a while, as I will be focusing more on chassis and suspension as or right now. From my previous car to this... this flexy F-body is in dire need of SFCs and LCAs with relocation kit/ TQ arm/ Panhard Rod/ new Bilstein sport shocks/ drop in the front only (I like how the back sits, plus I dont want to loose suspension travel back there, but the front HAS to come down a bit). AFTER this is when I'll get back on the engine. One step at a time.
All input welcomed! Im learning here so shoot!
Run#2- it was on it
Here's a question for you guys.
This is something I've only seen here on LS1-related stuff. On the dynos, WTF is all this talk about credits for tuning? I keep seeing some of the guys here talk about that and how (IMO) outrageously expensive it is for a tune for those that mention credits for dyno. Could someone please shed some light on that for me?
I came from a a 95 maxima to which I swaped a VQ35 into, built the engine and swapped it myself, and overtime I was tuning with things as simple as a SAFC and then upgraded to an E-Manage, always doing the tuning myself so I'd only have to pay for the dyno time. I never let someone else work on my car, even less tune it for me when i can do it myself.
Is the credits something that when you take the car in for someone ELSE to tune it?
Thats definetly a factory freak i'd say, very nice baseline. As far as credits go, tuning software requires you to buy credits before you can flash the PCM. Im not sure about EFIlive but with HPtuners its $50 per credit and it requires 2 credits to unlock that VIN for tuning. If you do custom operating systems it requires more.
Ooooh ok now it makes sense! I did see HPTuner mentioned a lot with the whole credit mombo-jumbo. Thanks for clearing that up!
Thanks guys! I am debating going to the track. It's quite a drive from here though. I dont have to worry about blowing up the differential with regular street tires right? lol It's slicks and DRs that I'd have something to worry about if Im not mistaken.
Six speeds have been known to break th ten bolt on highway runs. the t56 is the killer of 10 bolt rears. but then again stock ten bolts have also been known to run with 450rwhp cars that rund 11's. its a gamble.
I'm one of them. I left pretty easy on DR's but I was powershifting the hell out of it. Not even a whimper.
On the other hand I have a friend that broke his posi in 4th gear going through the traps, and another broke his posi in a bolt on LT1 with 2.73 gear leaving on street tires. Neither of them shattered the ring and pinion but they do the ol' 1 wheel peel.
Those are pretty impressive numbers. I'd like to see some numbers at the track as well.
1 Post
Impressive for only having a cleaned up K&N and no tuning. Keep us posted on your progress. I like that you are doing the suspension before you add power. Very smart.
It would've been interesting to have seen what she did before you got her up to speed. I'll bet she was way down !! Good job.
Thank you
Post up the graphs when the time comes!
Honestly I didn't even want to bother with dynoing in the state I got the car. The spark plugs had not been changed in 50k+ mi, the tranny and diff fluids were the original crap so they were black as night, air filter was black, etc...
w00h00!!!! This is my first time doing video editing! Anywho, watch and enjoy lol
http://www.youtube.com/watch?v=MFm7K...e=channel_page
All 3 runs in their respective sequence order.
OT- I guess while in there you can take a look at some of my other vids from my old Maxima. Unfortunately the only vids I had from when it was RMT'd was on just 6psi. Never got any from the 9-10psi days. Over on Maxima.org I had overlaid this dyno's runfile over the runfile from the last time I dyno'd All Motor on the Max... wow it just seemed like a cruel joke lol
That Max moved though. Full trim with full tank of gas it tipped the scale at Moroso at ~2950 w/o driver.
*Back in subject- LS1= w00h00!
