HKE L92 427 waiting to go in... dyno guess?
Old 04-07-2009, 08:29 AM
General Jack's Avatar
Default HKE L92 427 waiting to go in... dyno guess?
Just got my motor on Saturday. It will be a couple weeks before its installed and on the dyno, but to feed my excitement, how about some guesses as to my dyno #s? There will be no nitrous, so things like ring placement and piston specs were maximized for the NA application.
The mods:
  • 7.0 L92
  • TFS 235 heads
  • 254/262 112+3 (.646 lift w/ rockers)
  • Yella Terra 1.7 rockers
  • FAST 92 / 92 TB
  • 42 lb injectors
  • 85 mm MAF
  • 85 mm lid
  • Scat 4340 crank & I beam rods
  • Wiseco custom pistons, 5 cc relief
  • approx 11:1 compression
  • 15 lb flywheel
  • Moser 12 bolt 4.10s
  • 17x9 ZR1 wheels
  • N/A tune by Moe Bailey, no nitrous
Old 04-07-2009, 08:38 AM
jmilz28's Avatar
Even for a 427, that's a stout stick IMO.
Old 04-07-2009, 08:42 AM
LS1 Tech Administrator
Patrick G's Avatar
That's probably at least a 570-580 rwhp build if Erik touches it. Good cam size for a max effort build. Hope your tuner is a master!
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Old 04-07-2009, 08:46 AM
golfinz's Avatar
When you get this thing up and running I wanna hear what a 427 sounds like (Im in Austin too). If you can get 550+ outta it I might skip boost....
Old 04-07-2009, 08:49 AM
Nice, those are the kind of numbers I'm hoping for, which I believe would translate into close to 700 hp at the flywheel.
Yes, the tuning will be key and quite a project. The guy I'm using came well recommended, just like Erik did.
Old 04-07-2009, 08:50 AM
Originally Posted by golfinz
When you get this thing up and running I wanna hear with at 427 sounds like (Im in Austin too). If you can get 550+ outta it I might skip boost....
Sure thing, it will prolly be a little over a month. I need to break-in the new clutch before the dyno tune, and I can't start wrenching until next week.
Old 04-07-2009, 10:38 AM
8 Sec Tuner
Mike TexaSS's Avatar
Erik is da man.
Old 04-07-2009, 10:43 AM
golfinz's Avatar
Ive heard of Moe before, and from the work Ive seen, does good work.
Old 04-09-2009, 08:49 AM
Spellbound's Avatar
The mods:
  • 7.0 L92
  • TFS 235 heads
  • FAST 92 / 92 TB
  • 42 lb injectors
  • 85 mm MAF
  • 85 mm lid
  • 15 lb flywheel
  • 17x9 ZR1 wheels
I would say similar to this...
https://ls1tech.com/forums/10982167-post1.html
My girl friend is getting a motor by Erik similar to yours, but she will have a much smaller cam.
Old 04-09-2009, 09:06 AM
Krazy98Z28's Avatar
I would say 550 easy
Old 04-09-2009, 10:38 AM
bad95killer's Avatar
550+rwhp with perfect tune....keep us posted
peace
Old 04-26-2009, 08:16 AM
pharmd's Avatar
any updates?
Old 04-27-2009, 10:12 PM
No... been busy with work and family stuff. Just my luck. But I'll post when its up and running, and more importantly, when I break in the clutch and get it on the dyno.
