'98 H/C/I A4 just got dyno'ed. Lower #s than I expected
Car is a 1998 Camaro SS, A4
Mods are:
FRA mod
KN filter
Lid
85 mm MAF
90mm TB
Ported LS2 intake
Patriot 97-98 stage 2 CNC ported heads ( flow 292 intake, 216 exhaust @ .600 lift
Thunder racing cam 227/227 640/640 114 cam
1 3/4 stainless longtube headers
2.5 true duals, x pipe, dumped
160 thermostat
25% UD pulley
Fuddle 3300, 1.9 STR stall
3.73 gears in a 10 bolt
Rear tires are 315/35/17 nittos. Stock fuel injectors
Mustang Dyno
Came in with 358 RWHP unlocked with stock MAF on crappy street tune
Tuned with 85 MM MAF:
Unlocked made 370 RWHP @ 6656RPM and 321 TQ
Locked made 390 RWHP @ 6538 and 346 TQ
Tuned at Vector Motorsports just out side of Detroit
-Vector is across the street from Katech engineering, and they do their chassis dyno tuning
What do you guys think?
Mods are:
FRA mod
KN filter
Lid
85 mm MAF
90mm TB
Ported LS2 intake
160 thermostat
25% UD pulley
Mustang Dyno
Mustang dyno's normally read low, but I would most certainly ditch the LS2 intake manifold it's no good. You should see a good pick-up at the wheels with a fast 92 or even a LS-6 intake.
Those are real world numbers for a mild setup, with a loose converter and that type of dyno.
Put a sticky tire on it and take it to the track. Try not to pay too much attention to the internet 450rwhp dyno manual trans cars in your rearview mirror.
You may want to reconsider that converter you've got though. A more aggressive stall speed coupled with a more efficient design will do wonders.
Mods are:
FRA mod
KN filter
Lid
85 mm MAF
90mm TB
Ported LS2 intake
160 thermostat
25% UD pulley
Mustang Dyno
Mods are:
FRA mod
KN filter
Lid
85 mm MAF
90mm TB
Ported LS2 intake
160 thermostat
25% UD pulley
Mustang Dyno
It rained a little bit when I was there. The first run I spun so bad I just coasted to the end. The next 3 runs were consistant but not very good
Run 1 / Run 2 / Run 3
60 ft 2.1 2.09 2.05
1/4 ET 13.0 12.92 12.90
MPH no MPH 106.5 106.9
Like I said it rained there. Car does have suspension mods. 17 PSI in the nitto drag radials.
I'm not worried about the times at all cause of the traction issues, but isnt that 106 MPH pretty weak for a 390 RWHP H/C/I/E car?
My **** stalls from them too. Kirk did not even work on my car
Because steve is a complete retard. I brought my car home, stalled many many times. Hooked up my HPT and my AIC counts were zero throughout the entire temp range. Something so easy, and he didnt catch it.
Steve did not do ANY street tuning. I paid for a FULL Dyno tune. He took it for a 5 minute (Literally) drive. Thats it. A damn monkey can tube WOT on the dyno, the hard part is getting the driviability right.
I would never, ever, recomend Vector to anyone. Screw Steve, and his bitchy atitude.
I just ran the car at the track again.... Same low 106 MPH....
This time I ran at Milan dragway (much better than Lapeer)
Run 1 Run 2
60ft: 1.76 1.93
1/8 ET: 7.8 8.1
1/8 MPH: 87.5 87.1
1/4 ET: 12.40 12.76
1/4 MPH: 106.8 106.3
I cleaned the air filter between this trip at the track and the last time as well as checking all of the TR55 spark plugs. They all looked great and I reset the gap at about .52
There was an LS2 GTO there, M6 with heads and cam. STOCK LS2 intake and he ran 12.1 at 117 MPH - So I dont think my ported LS2 intake is the problem.
My guess is the problem is either the tune or the Fuddle converter. I am sure it is one of the two.....
Run 1 Run 2
60ft: 1.76 1.93
1/8 ET: 7.8 8.1
1/8 MPH: 87.5 87.1
1/4 ET: 12.40 12.76
My car trapped 106 bone stock on 7 cylinders...
brand new LS1 Longblock from GM and full exhaust and I was trapping 111.....
added a Cam and now im trapping 116.
Your tune is shitty, or your verter isnt helping you....or its both.
