Are my bolt-on dyno numbers low?
Old 05-28-2009, 04:57 PM
Chase22's Avatar
Default Are my bolt-on dyno numbers low?
We only got one pull in before the dyno computer wouldnt work for some reason but there was a street tune beforehand. I plan on going back when I have the time. My numbers were 337 hp 312 ft/lb / torque on a dynojet with mods in sig.
Old 05-28-2009, 05:01 PM
LS1crazy01's Avatar
What kind of dyno?
Old 05-28-2009, 05:09 PM
matt3383's Avatar
torque seems lower than it should be. HP is right around where exh/intake car should be. Im assuming you have a stock drive train correct?
Post up the graph if you can, that usually will tell the story
Old 05-29-2009, 01:53 AM
VeTTeMaNC486's Avatar
torque seems low but hp seems right. What wheels? I see bigger rear tires, heaver drivetrain components eat some power. A UDP and EWP might get you some gains too if you are looking for better numbers.
Old 05-29-2009, 07:35 AM
PewterScreaminMach's Avatar
x3 on the low torque. HP looks fine if these are SAE dynojet numbers.
Old 05-29-2009, 05:59 PM
Chase22's Avatar
I dont have a graph seeing as how we could only do one pull because the computer starting malfunctioning afterwards. I have 17's 275 on front and 18's in the back 295. Do people with just bolt-ons usually see better results in following pulls?
Old 05-29-2009, 06:11 PM
TheBlueKnight's Avatar
If the dyno computer stopped working after that pull I wouldn't believe the first pull's numbers, numbers seem low to me.
Old 05-29-2009, 06:30 PM
JScamaro's Avatar
With the stock cam, generally your torque should be higher than your horsepower.
