2000 LS1 Miata burning lean and making 353HP/358TQ
Old 02-04-2011, 10:14 AM
rmcelwee's Avatar
Default 2000 LS1 Miata burning lean and making 353HP/358TQ
My first post here. I purchased a Miata with an LS1 (the seller is/was a member here and had the car posted on here a few months ago) and took it to the dyno last week. The car runs a little lean and I figure I could get a bit more power out of it if I increased the fuel but I'm really not looking for a dyno queen. I only drive the car on the street and the Miata really doesn't need more than the 353 it is making. So what am I doing posting here? I'm really just wanting to show off the dyno graph and see what you guys think about the A/F. I also wanted to know how hard it was to add a little fuel to it (i.e. buy a $10 cable to attach my laptop to the OBDII port or is it more in depth than that). Of course, I'm also saying Hello (first post) but I am not sure if I will ever tear into the engine. I'm more of a Miata guy instead of an LS1 guy (our only Corvette was an '84 <G>). Thanks!
Video of the dyno:
http://www.youtube.com/watch?feature...&v=guDeguZUfUk
A link to the DRF file:
http://www.lightweightmiata.com/v8/d...y_01-28-11.drf
Old 02-04-2011, 12:40 PM
disc0monkey's Avatar
just pay to have it professionally tuned and post a graph of the SAE numbers please!!
Old 02-04-2011, 12:52 PM
rmcelwee's Avatar
I've had bad experiences paying to have a professional tune. Not many "professionals" around here.
SAE:
Old 02-04-2011, 04:02 PM
Ragtop 99's Avatar
You hit 14:1 and that's leaner than I would run.
Unfortunately to adjust it, you need more than a $10 cable. If you don't trust a pro, find someone around you with HPT or EFIlive. Typically costs about $100 to add a car to the program and use their cable. Have them touch it up and buy them lots of beer afterwards.
I like high powered miatas. Fun toy.
Old 02-07-2011, 06:38 PM
rmcelwee's Avatar
Well, your message scared the hell out of me. I will definitely get the car tuned soon. I'll post the results...
Old 02-07-2011, 08:11 PM
Detoxx03's Avatar
Yeah it needs a tune bad cause that is too lean.
Old 02-08-2011, 07:52 AM
jmilz28's Avatar
LS1Tech 10 Year
Check the basics too, pump, filter, and INJECTORS. Stock are fine but they may be dirty or getting old/weak.
Regardless, I'll bet that is a blast to drive!
Old 02-09-2011, 09:32 PM
rmcelwee's Avatar
The guys that did the dyno said they would give me a tune for $300. What ratio should I be shooting for and should it be the same across the entire power band?
Old 02-09-2011, 09:49 PM
180ls1's Avatar
$300 is not bad for a full tune, but i can see where you are coming from about paying that much just to fix your afr.
There is a guy search on google for "frost tuning" he is very good at mail order tunes and might be able to help you.
Where are you located and are there any internal mods to the car?
Old 02-10-2011, 06:55 AM
rmcelwee's Avatar
I'm in Charleston, SC. The engine has different springs and a more powerful cam.
Old 02-10-2011, 08:18 AM
dont you mean different cam and more powerful springs? haha
but seriously $300 to correct your afr and bump the timing around isnt bad.
Old 02-10-2011, 09:08 AM
Old Geezer's Avatar
The fuel pressure is???????????
Old 02-10-2011, 06:40 PM
Ragtop 99's Avatar
For $300 there is no magic #. He should be experimenting and give the car what it wants. I'd start with 12.5 around 4500 and and experiment from there. My recollection is that LS1 seemed to like it a little richer around peak torque and about 13:1 around peak HP. I haven't tuned an LS1 in years so don't take that as gospel.
Old 02-11-2011, 12:23 AM
minytrker's Avatar
LS1Tech 20 Year Member
I posted on the local forum (CHP)who you need to call for a tune.
Old 02-11-2011, 08:03 AM
rmcelwee's Avatar
No idea. I'll have to hook up a gauge and take a look.
Old 02-12-2011, 07:19 PM
rmcelwee's Avatar
We didn't get a fuel pressure gauge on it today but the lean spot was taken out and all is well. The tuner said I was running about 90% duty cycle so I'll have to consider that if I do any upgrades to the engine (I doubt that I ever will but who knows).
Old 02-13-2011, 12:34 AM
minytrker's Avatar
That A/F isnt very smooth.......its also rich
Quick Reply: 2000 LS1 Miata burning lean and making 353HP/358TQ
