02 F-body: ASA Cam & Bolt-Ons
Old 02-07-2011, 03:11 PM
LS1Aggie09's Avatar
Default 02 F-body: ASA Cam & Bolt-Ons
THANKS MIKE@G-FORCE!
Got it tuned today. It was loud as ***** at 6800 rpms . set the rev limiter at 6600 and shift point is going to be around 6500. i was thoroughly impressed with the repeated dyno pulls putting out the exact same numbers within a couple high or low. Mike is an excellent guy with a lot of knowledge. got a couple other things taken care of while i was at the shop I am very impressed with the cam as it is virtually IDENTICAL curves to the factory cam just moved several tq and hp higher.
this was a good average of the results.... the fan was turned off that was in front of the car during the dyno runs so it's accurate. This is with no forcefed air like most do.
Uncorrected Raw Data of the power it made today 397/382
Uncorrected First dyno I did with just a lid and catback 332/345 (gain of 65/37 but i believe it'd be more if i were comparing corrected numbers)
Corrected Data (expected more out of it but comparing to my friend's numbers at the exact same location [382ish/372ish] with a Torquer 3 & Bolt-ons, I am pleased with how the cam did) 375/360
Old 02-07-2011, 09:26 PM
RJB01camaross's Avatar
Good Numbers!!!
Old 02-07-2011, 10:32 PM
30th t/a's Avatar
do you have LT's?
Old 02-08-2011, 01:07 AM
LS1rob00's Avatar
What are the specs on the cam?
Old 02-09-2011, 07:58 AM
rob69zombie's Avatar
Awesome results for that ASA.
Old 02-09-2011, 08:54 AM
180ls1's Avatar
nice numbers, whats your exhaust setup?
Old 02-09-2011, 02:50 PM
LS1Aggie09's Avatar
Kooks 1 7/8" to catted y-pipe to a loudmouth...pretty free-flowing
Old 02-10-2011, 05:49 PM
litle88's Avatar
Nice I get it idles like a beast on that 110 LSA!! I loved my hotcam when I had it, I made 403 hP with that cam, full bolt
Old 02-10-2011, 05:51 PM
litle88's Avatar
Nice I bet it idles like a beast on that 110 LSA!! I loved my hotcam when I had it, I made 403 hP with that cam, full boltOns, UDP, and a FAST 90/90, and harland 1.8 rockers with a magnaflow. enjoy it bud!
Old 02-25-2012, 10:36 PM
Hugger67RSSS's Avatar
I'm wanting to use this cam in my LS2 for my 68 Camaro because it won't require a spring change. Nice to see that it makes good numbers until I decide to upgrade the whole motor
Quick Reply: 02 F-body: ASA Cam & Bolt-Ons
