TReX dyno - 1998 SS - cam only
420/380
Stock Heads
Dual Valve springs
Katech Rod bolts
LS6 intake
Ported TB
3 inch duals into 4x9 magnaflows
6spd
Stock 10bolt 3.73s
Time to buy a FAST intake
Stock Heads
Dual Valve springs
Katech Rod bolts
LS6 intake
Ported TB
6spd
Stock 10bolt 3.73s
No track times working on weight reduction on the car now and waiting for winter to swap in a TH350/9inch also need to finish up suspension over winter.
Just trying to get some baseline numbers
However every other gear is fine even low rpm in 5th and 6th.
