Comp 224/230 XER cam results
Old 01-01-2012, 07:32 PM
solidsnakecsm101's Avatar
Default Comp 224/230 XER cam results
I found my brothers dyno sheet while doing some cleaning today. He said i could post it.
Car specs bellow
2000 Camaro SS
6 Speed
Stock LS1 Block (with about 70K miles at the time)
Fidanza Al flywheel
Spec stage 3+ cluth
LS6 Intake
85mm TB
42lb Cobra "Blue" injectors
Tick Master
CNC LS6 Heads by Superior Automotive (they have a flow bench and flow 306/227 cfm @ .550 and 312/229 cfm @ .600)
Comp XER 224/230 .588/.592 114LSA
Scorpion New Style 1.7 roller rockers
Comp Pushrods
Comp Lifters 850-16
Melling High Volume oil pump
1 3/4 FLP Long Tubes High flow cats and Y pipe
Magnaflow Catback
Stock 10 Bolt with 3:73 gears
Here is the link to the dyno vid
http://youtu.be/Clm92HJNrMo
Attached Thumbnails Comp 224/230 XER cam results-carlos-dyno-sheet.jpg
Old 01-01-2012, 07:39 PM
Forgot to include :
Patriot Gold Dual valve springs
Under drive Pulley
Old 01-02-2012, 09:33 AM
SideStep's Avatar
Solid numbers, TQ curve looks like a shelf!!!
Are these SAE or STD correction???
Old 01-02-2012, 09:40 AM
STD corrected.
Old 01-04-2012, 07:03 PM
Killer5.3's Avatar
Nice. That car should feel really strong with that torque curve. You may have given up a few peak hp compare to a bigger cam , but car will be much quicker because of better average power especially with the mild gears and street weight.
Old 01-05-2012, 10:22 AM
thunderstruck507's Avatar
Looks like the pull ended early to me. Wonder what it looked like with another couple hundred rpm?
Old 01-08-2012, 08:37 AM
TrentSS's Avatar
Now that's what I call power-under-the-curve! That 402 ftlbs. has got to feel great on the street...
Old 01-10-2012, 08:39 PM
SAPS's Avatar
I have the same cam and LS6 heads on my vette. Thru the stalled/auto 391 at the wheels.
Old 01-14-2012, 03:01 PM
DunnoWhoThisIs's Avatar
i had this cam with prc stg. 2.5 5.3 heads and i loved it! ran awesome.. def gonna put this cam in my daily when i rebuild the motor.
Old 01-15-2012, 10:11 PM
yonerhottlt1's Avatar
Yea it looks like it still has more left in it as well. Good numbers either way
Old 04-01-2012, 10:36 AM
Heres the best part....he passes the cali sniffer with no trouble at all.
Old 04-01-2012, 06:41 PM
Johnnystock's Avatar
Originally Posted by yonerhottlt1
yea it looks like it still has more left in it as well. Good numbers either way
+1...
Quick Reply: Comp 224/230 XER cam results
