EPS 226/234 Cam only
Old 05-03-2012, 05:43 PM
nurmikko22's Avatar
Default EPS 226/234 Cam only
I have an 02 M6 Trans am & I just put in the EPS 226/234 113. After a day at the dyno it put down 376/371. It's about what I expected.
EPS 226/234 Cam only-tune.jpg
Old 05-03-2012, 06:00 PM
Johnnystock's Avatar
What boltons? auto/man?
Old 05-03-2012, 06:08 PM
*02WS6TURK*'s Avatar
Good cam choice. M6?
Old 05-03-2012, 07:00 PM
94zGreen's Avatar
It says M6 ^^ but I think those are pretty great numbers, I have a 230/238 and really hoping to break 400 with it... we shall see next weekend when it gets dynoed!
Old 05-03-2012, 07:08 PM
Wow I'm blind! Same cam here. With bolt ons I hit 401rwh 392rwt before the FAST 92/92, magnaflow & cut-out went on.
Old 05-03-2012, 08:44 PM
Captain Double Post
BOBS99SS's Avatar
I dont think there to bad of numbers at all, good choice on the cam now just get some heads and it will really shine
Old 05-03-2012, 08:59 PM
Camaro Z's Avatar
Time to take it to the track!
s346k's Avatar
i wouldn't call those numbers great. not terrible either. dynos are tuning tools so results aren't worth a ton of effort.
however, it seems to peak early for a 230* cam..
Old 05-04-2012, 09:22 AM
thunderstruck507's Avatar
Peak seems early and low numbers. I'm guessing both of those are attributed to lack of headers/exhaust I hope.
What other mods does the car have?
Old 05-04-2012, 04:09 PM
nurmikko22's Avatar
Talking
It is a manual, and it has the usual headers and lid. Before the cam I ran a best of 12.69 @ 111mph (with a crappy 60ft), so I'm ready to see what it will do with the cam. I told Geoff at EPS that I wanted an "area under the curve" cam and didn't want to spin real high to get power. I did notice that they only went to 6200 rpm on the dyno, so that coupled with an early torque peak is going to hurt my peak HP numbers. Either way, I like the cam so far and the track will really tell how much I picked up (and now that I will finally be able to go by my buddies Fox body
Old 05-04-2012, 04:28 PM
Headers as in LT headers? Mids? Shortys? If you have LT's and a lid, I would say you are down on power. With bolt ons, 4.10's and that same cam, I put down 401rwh.
Old 05-04-2012, 04:33 PM
nurmikko22's Avatar
yeah, they are long tubes. Maybe my tuner isn't that great, not sure why the same cam is lower? Or maybe the dyno's are different? Do you have before/after times for your cam?
Old 05-04-2012, 04:47 PM
Nope. I haven't tracked it yet. I did have UD pulleys which you do not. Other than that, that is it and that wouldn't be a huge difference in HP. Stock exhaust at the time too.
Old 05-04-2012, 07:57 PM
s346k's Avatar
that cam peaks at like 5800...that's not too terribly off from a stock cam. i dunno, i hope it runs better than the dyno shows. if it trapped 111 with a stock cam i'd like to think adding something like that would bump it up to 115 at least.
Old 05-04-2012, 08:17 PM
I think 5800 is really early for a peak too...but tell us how it does on track, you will know if its good or not.
Old 05-05-2012, 06:21 AM
gtotoocool1's Avatar
peak looks early to me as well,i would be more concerned with that then the dyno #s..what was the ICL?
was the preload checked?what valvesprings?
Old 05-05-2012, 07:46 AM
disc0monkey's Avatar
This I would start being curious about the icl as well. Turk where is your graph. Maybe it can lead to something if we superimpose it and see if the curve is moved to the left in the graph.
Old 05-05-2012, 10:26 AM
nurmikko22's Avatar
The ICL is 111 and I have the PAC 1518 springs.
Old 05-05-2012, 11:09 AM
did you check your preload?what's the pushrod length?
Old 05-05-2012, 01:24 PM
Was that verified by decreeing the cam? That's what I was sugggesting
Quick Reply: EPS 226/234 Cam only
