Simple combo-big power-347+D1SC=800+rwhp
Old 09-20-2012, 09:25 PM
eb02z06's Avatar
Default Simple combo-big power-347+D1SC=800+rwhp
Just a little 347, Patriot Stage 3 317 heads, D1SC 3.55 pulley, meth and one of my cams.
Old 09-22-2012, 01:05 AM
STEEPSS's Avatar
OMG look at that torque curve
Super solid combo sir.
Old 09-22-2012, 07:12 AM
Pray's Avatar
Wow, you have done it again my man. Those are almost exactly the same numbers the 408 YSI at 14lbs made that I did. I did find one little issue with my build that probably didn't cost anything but you never know. Great work.
Old 09-22-2012, 12:03 PM
Sales@Tick's Avatar
600rwtq+ from 4300 to 6800...very impressive!
Old 09-24-2012, 08:22 PM
eb02z06's Avatar
Thanks buddy! Gonna send you a PM on something.
Old 10-01-2012, 12:55 PM
Jwright41's Avatar
What was used for the internals? Amount of boost?
Old 10-01-2012, 01:16 PM
eb02z06's Avatar
Eagle rods, off the shelf Diamond pistons, stock crank. 18-19 psi.
Old 10-01-2012, 04:01 PM
Jwright41's Avatar
That is cool!! Any reason why you didn't do a 383? Just wondering if there would be any difference, besides the parts, on power.
Old 10-01-2012, 07:00 PM
eb02z06's Avatar
Customer wanted to go the cheapest route possible and make 750 rwhp.
Old 10-02-2012, 07:01 AM
TrentSS's Avatar
That's awesome power out of a forged 347. 713 ft. lbs. peak torque...holy cow!
Old 10-05-2012, 10:37 PM
BLWN1's Avatar
Going to be any track times?
Old 10-05-2012, 11:07 PM
eb02z06's Avatar
Missing 4th gear and the meth failed pulling timing back to 4 degrees and adding fuel.
10.7@131, not too bad considering.
Going to do some suspension mods and do a rental soon.
http://youtu.be/chkL2LLoE8c
Old 10-05-2012, 11:20 PM
BLWN1's Avatar
Any clue on the 1/8 et?
Old 10-06-2012, 09:08 AM
Sales@Tick's Avatar
I see that you are using the PE fuel adder versus IAT and IAT spark in case the meth fails like it did to add the fueling back into the tune that the methanol would normally carry itself along with pulling timing if the IAT's rise.
IMO that is the best and most effective fail safe you can have with methanol injection.
To make it work properly though in case of emergency you have to have enough fuel injector and fuel pump to take over the load of fueling that the methanol would of carried itself. As long as you're able to cover that amount of fuel with the injectors and pump you're golden and there is no possible way to hurt the motor if and when the methanol pump fails.
I don't see many tuners using the IAT adder only the IAT spark, but kudos to you for doing it. Works like a charm.
You guys got a Tick Master in that thing?
Old 10-12-2012, 12:37 PM
70 gsconvt's Avatar
What's cheap? I have an LQ4 that I'm going to put a 4.000 stroker crank into along with new rods and forged slugs. I was figuring on GMMP CNC LS3 heads, a FAST 102 intake/tbi. I haven't settled on a cam yet. I've always been a naturally aspirited guy, but I've seen the awesome power with a D1SC and a turbo's waste gate can do. It's all going into a 1978 Z28 street car.
Old 10-12-2012, 05:38 PM
KrisR's Avatar
Which block is it? Amazing setup!
Old 10-12-2012, 06:32 PM
eb02z06's Avatar
LS1 block
Old 10-13-2012, 10:26 AM
Jerm__'s Avatar
Very nice!
Old 10-13-2012, 11:00 AM
KrisR's Avatar
Jeez. I guess I've been out of the loop for too long (just bought another LS car after being away for 5 years) but I was under the impression that the stock aluminum blocks squirmed around too much at anything over 550rwhp or so?
Old 10-14-2012, 10:22 AM
fotoboy's Avatar
Well u have seen my setup. So far this year 4500 miles and no issues! Fi is in ur future! Where did u get the idea that they have issues over 550?
Quick Reply: Simple combo-big power-347+D1SC=800+rwhp
