Lq4 6.0 dyno numbers
Old 11-05-2016, 06:35 AM
zboy2012's Avatar
Default Lq4 6.0 dyno numbers
So I finally finished my build and got it tuned by Mike Norris. Here is the setup
99 Trans Am
stock cube 2000 lq4 with factory ls1 crank ARP rod bolts
Stock ls6 intake and Stock ported throttle body
pacesetter longtubes
Phab x-pipe
BTR custom grind cam 237/252 .622/.596 113
FTI 4400 converter and RPM built trans
Fluidampr
36# injectors
FTP lid
Chris 1313
and stock 799 heads.
Herr are the numbers it made on his dyno with the converter locked and unlocked.
Old 11-05-2016, 07:46 AM
zboy2012's Avatar
Are these decent numbers?
Old 11-05-2016, 09:32 AM
hpfiend's Avatar
I am def not an expert but it seems like there would be a lot more with that cam and supporting mods if you ported the heads. I thought 317s were the stock LQ4 heads?
But that said over 400 at the wheels is no slouch!!
Old 11-05-2016, 08:40 PM
SoFla01SSLookinstok's Avatar
Looks real good. Should run strong. Power still carrying great at 7300rpm. I bet she'd really like a FAST.
Old 11-05-2016, 10:56 PM
zboy2012's Avatar
Stock heads are 317's but I bought it as a shortblock and threw my stock 799 heads on it. I thought about porting and milling the heads some but got a goal of running 10.9 first then going crazy lol.
I've thought about throwing a fast intake on it down the road sometime soon also!
Old 12-17-2016, 10:48 PM
vwdave's Avatar
Damn, yours did alot better than mine did with ported 317's and a much smaller cam.
Old 08-07-2017, 06:12 AM
zboy2012's Avatar
Ya it was just a budget. Build lol.
Old 08-07-2017, 07:12 AM
HCI2000SS's Avatar
Ever run it at the track?
Old 08-14-2017, 04:41 PM
foxsl's Avatar
A stall that high is probably never going to make sense numerically on the dyno, I found this out the hard way. Unless your engine modifications are performed on the same converter as the baseline before mods, dyno numbers are almost useless unless you use the dyno to see gains from fueling and ignition timing.
Old 03-25-2018, 05:56 PM
zboy2012's Avatar
Wow ever even knew there was a reply on this lol. Ya I ended up running it and ran the 10.9 pass I wanted. Ended up selling the car to my brother and now have a 2000 1SC SS 6 speed car.
Old 03-25-2018, 06:06 PM
98CayenneT/A's Avatar
Originally Posted by zboy2012
Wow ever even knew there was a reply on this lol. Ya I ended up runit and ran the 10.9 pass I wanted. Ended up selling the car to my brother and now have a 2000 1SC SS 6 speed car.
Remember what you trapped and what 60' that converted got ya?
Old 03-25-2018, 06:16 PM
subeone's Avatar
those numbers sound right.
Old 03-25-2018, 08:54 PM
zboy2012's Avatar
1.4x 60’ and if I remember right mph was like 124. I’d have to dig around for the slip.
Old 03-25-2018, 09:23 PM
HCI2000SS's Avatar
That's impressive. What does it weigh?
Old 03-25-2018, 09:32 PM
zboy2012's Avatar
Pretty close to full weight, never really weighed it after pulling the front and rear supports pulled, front sway bar was pulled as was the rear seats, no a/c, no power steering with a looped factory rack. Other than that it was stock suspension. The car ran 11.37 with the old setup I have on here somewhere.
Old 03-25-2018, 09:42 PM
HCI2000SS's Avatar
Sounds like you do have a bit of weight pulled for sure, but obviously nothing crazy. I know when my buddy pulled about 200 lbs out of his Mustang he dropped 3/10's and gained 2 mph
Old 03-25-2018, 10:24 PM
Received 3,022 Likes on 2,353 Posts
He got a different driver? lol
Old 03-26-2018, 06:02 PM
zboy2012's Avatar
Ya haha but definitely not 200 pounds worth I wouldn’t think haha. I know it weighed 3485 with me in it before I pulled the stuff listed.
Old 03-26-2018, 08:53 PM
kinglt-1's Avatar
Good numbers for a big stall.
Old 03-27-2018, 03:08 PM
zboy2012's Avatar
Thank you sir! I see you’re from IN also. Hope to see you out sometime at one of the tracks lol. Which do you normally run at?
Quick Reply: Lq4 6.0 dyno numbers
