444hp 394tq on a Mustang Dyno
Old 03-13-2005, 09:21 PM
Hawkn01's Avatar
Default 444hp 394tq on a Mustang Dyno
Got the new motor together and and had it dynoed on a Mustang Dyno this weekend.
The motor is a 347ci forged bottom with 5.3 stage 2.5 heads, Fast 90mm intake and TB,Kooks stepped headers,Th-400, 12bolt/4.10 gears, 28" Hoosier drags.
The best pull it made was 444hp 394tq
Old 03-13-2005, 09:29 PM
Bo White's Avatar
What cam and brand of heads? Great #s on a Mustang
Old 03-13-2005, 09:31 PM
GrannySShifting's Avatar
In his sig.
Old 03-13-2005, 09:32 PM
congratsTJ!
Old 03-13-2005, 09:44 PM
Hawkn01's Avatar
The cam is a hyd custom grind by Lethal EFI Performance. The heads started out as AS 2.5's but were reworked by Tin Shed Racing. All machine work to the block was done by a local machine shop here called The Shop.
Old 03-13-2005, 09:50 PM
Bo White's Avatar
Thanx, I seen the sig after posting and didnt change it since the cam was still unknown. Also I hadnt heard of TSR and was also curious, looks like the cam specs are
Old 03-13-2005, 10:29 PM
Hawkn01's Avatar
Bo White, I'm sorry to say they are secret. I'm not suppose to reveal their custom grind spec's per my agreement with Lethal EFI Performance. In order for me to keep their support I must do as they wish, sorry.
TSR = Eric Bradby from "E.B. Porting" in Providence Forge, Va.
TJ
Old 03-13-2005, 10:32 PM
chaos's Avatar
This may be a dumb question, but what's the difference between a mustang dyno and any other dynoe?
I can shift faster than you.
Jason99T/A's Avatar
Nice #s TJ? What kind of compression ratio is the new motor running?
Jason
Old 03-13-2005, 10:43 PM
Joe Overton's Avatar
Tim you left out the pulls were made with 93 octane pump gas
Old 03-13-2005, 11:00 PM
Hawkn01's Avatar
Jason, CR is 11 to 1. and as Joe stated the pulls were made on 93 pump gas.
Old 03-13-2005, 11:11 PM
Hawkn01's Avatar
Dynojet= 3000lb weighted roller
Mustang dyno= the roller is controlled by eddy current. As rpms go up it increases drag to simulate real world conditions.
Old 03-13-2005, 11:17 PM
DanZ28's Avatar
Those are awesome numbers!
Considering this is a mustang dyno and through an unlocked TH400, 12 bolt/4.10's, those numbers are very impressive. If this were an M6 stock rear end car on a dynojet, you would see 480ish I bet...
I think mustang dyno's are load dyno's, correct? they show x % drivetrain loss over a dyno jet.
Edit: you beat me to it..
Dan
Old 03-14-2005, 09:31 AM
Hawkn01's Avatar
Dan
Dan, they have several mustang dyno models to choose from. This paticular model can handle up to 2000 hp and has a large single roller.
Old 03-14-2005, 09:59 AM
JS
JS's Avatar
Very very impressive..
The Mustang dyno tells me this setup wouldve made another 25RW over a dynojet not to mention the TH400 is killing power,This engine would make over 500RW threw a 6sp
I dont know why u would wanna run more than 93 octane with 11.1,that should be fine w/our engines but this is Lethals setup so they would know more than me.
Hawk u have one amazing setup
Now go run those 9's...
Old 03-14-2005, 10:19 AM
Hawkn01's Avatar
JS, thanks for the compliment. Right now in the cooler weather there is no need for anything higher than 93 pump gas with this combo. Maybe when it gets warmer I might need a mix to bump the octane up alittle.
Old 03-14-2005, 10:47 AM
JS
JS's Avatar
Gotcha
Old 03-14-2005, 11:18 AM
put some compression in that motor next go round Joe!
Old 03-14-2005, 11:25 AM
Hardtop's Avatar
Congrats TJ. I'm sure your car will be one of the cars to beat with 347 ci and a hydraulic cam. You and Joe have been busy over the winter. 9's N/A would be awsome. When are you coming to MIR?
Bruce
Old 03-14-2005, 11:45 AM
Restricted User
2001 Pewter WS6's Avatar
Why is the torque so low if this is an unlocked converter? Numbers don't make sense. That is a whole lot iof HP for a 347 through a T400 on a Mustang Dyno. Post the graph...
