mustang dyno numbers only plez
Old 05-09-2006, 12:25 AM
obZidian's Avatar
Default mustang dyno numbers only plez
Basically, im trying to put together some info for a large database type of post. I want to start with this for now so it can get started.
Thus, if you can, please post your mustang dyno numbers only with a quick word on your combo, m6 or a4 (very important) operator, if you can, and/if you have any track times, plez imclude that as well if you can.
Thank you, this will go to the Anti-how much will I make threads foundation.
Thanks again!!
Old 05-09-2006, 10:25 AM
01bird58's Avatar
brother made 401rwhp with cartek *edit *228/222* cam, ported heads, bolt-ons. Best 1/4 on street tires 12.4@117
Old 05-09-2006, 10:35 AM
joshp14's Avatar
01 TA M6, F13 cam & bolt-ons, 367 rwhp/344 tq mustang dyno, 12.5@116 street tires
Old 05-10-2006, 12:15 AM
obZidian's Avatar
thanks ya'll, thats perfect...
anyone else?
Old 05-10-2006, 12:38 AM
LSs1Power's Avatar
Check sig
Old 05-10-2006, 06:53 AM
BLAKE 01 WS6's Avatar
check sig
Old 05-10-2006, 08:32 PM
black_z's Avatar
308/328 M6 LT's, cutout, March UD pulley, lid. 12.900@109.5
Old 05-10-2006, 10:24 PM
obZidian's Avatar
awesome ppl...
Im trying to get some info together and this is adding to the pot...
Old 05-11-2006, 08:57 AM
evil02z's Avatar
02 z28 m6
5k on the car slp lid, K&N, hollowed cats, & dynomouth exhaust
331 RWHP 360RWTQ 13.2 @110 2.3 60'
previous mods + hooker LT's crappy crimp bent y & magnaflow oem replacement muffler
lunati 222* 228* .534 .544 114 LSA hand ported 5.3s & TB 160 t-stat 4.10s
405 RWHP 408RWTQ 12.2 @117 1.9 60'
Old 05-11-2006, 10:12 PM
mike c.'s Avatar
01 ws6-afr 205 heads,g5x4 cam,fast 90mm w/nk-willians,85mass air,wisper lid,172 t-stat,asp pulley,1/34kooks w/off roads w/b&b catback,m6 trans 12 bolt w/4.11 gears. 457.9hp 400tq mustang dyno. no short belt tricks,stock weight flywheel,everything hooked up.
Old 05-13-2006, 09:54 AM
NOS327's Avatar
dang, 6 of 7 haven't posted their results in my thread on rear wheel power and track performance trends in this same forum. obZ, I gotta thread jack a little here... can you guys jump over to this thread and get your results posted along with your weight??
Thanks, TJ
Old 05-13-2006, 12:47 PM
mike c.'s Avatar
i already posted once but i went back to the dyno today(mustang dyno) i had some timing and fuel issued to be solved. so...we got her fixed and retuned the #'s were 463.0hp @6500 413.8tq@4,700. i gained 5hp and 13.9 tq more when we fixed the problems.
Old 05-15-2006, 03:08 PM
NYTIGER's Avatar
2005 GTO 6.0 LS2 > K&N Aircharger; 160 stat; predator tune.
320RWHP/358RWTQ
Times in signature are stock on stock tires.
Old 05-15-2006, 03:34 PM
Jefro6996's Avatar
420rwhp and 385rwtq 99 z28 with an M6. 5.3l heads, 231/237 cam, and bolts-ons. ls6 intake
12.1@118 with 2.0 60 foot.
Old 05-15-2006, 04:11 PM
obZidian's Avatar
Any large cubed, autos or m6 on a stang dyno?
Mike C.: Those looks quite impressive, stock cubes i imagine, right? Those look like dynojet numbers with your same mods... where did you dyno it at if you dont mind me asking?
Old 05-15-2006, 04:26 PM
Snapps's Avatar
Mustang Dyno:
Dyno'd @ EPP brent did the dyno run .
499.4rwhp / 468rwtrq only ran up to 6400rpm running rich. Partial Tune via email TSP TUNE.
2001 T/A Ws6 M6
Motor Spec's: TSP 408 shortblock w/ AFR 225 heads (out the box)TSP GIANT 113 +2 ASP UD Pully,Fast 90mm Intake, NW 90mm TB, 85mm GM MAF, Hooker LT's, TSP Catted Y pipe, Borla Catback. Now I am running Pace setter LT'S with Pacesetter ORY' still working on the tune. Hope this helps ya
Last edited by Snapps; 05-15-2006 at 04:48 PM. Reason: forgot a few parts and trans. type
Old 05-16-2006, 11:36 PM
obZidian's Avatar
No, thats exactly what im looking for!!
Man, bobs dyno cant get a even number even if he tried...
Almost every number is like 499hp or 495 or 595hp. Its close to the next mark but not quite enough!!!
Old 05-17-2006, 11:46 AM
LT99LS1's Avatar
410rwhp / 393rwtrq 11.92@120 383-M6-9inch car is setup for RR/Autox. Car was about 90% done with tune at the time. Ran out of valve springs @ 5800 rpm.
I got a better Valve springs/Intake/TB/MAF and fuel system now. Just got to go back and get some new numbers.
Old 05-18-2006, 01:39 PM
obZidian's Avatar
not bad....
Old 05-24-2006, 04:29 PM
tx77015ls1's Avatar
Look in sig for mustang dyno numbers 2000 Z28 A4 94000 miles
I did 314 HP with 87 octane with the adition of the SLPsmooth belows
