Is it possible to put down 430-440hp with tr224?
Old 05-17-2006, 07:52 PM
SPRAYED 01's Avatar
Default Is it possible to put down 430-440hp with tr224?
All mods in sid with tsp ls6 heads and a fast 90/90 intake setup. Dyno tune by Finish Line Performance. Did 397hp and 386ftlbs with mods in sig only.
Old 05-17-2006, 07:53 PM
'Trust''s Avatar
Your adding the LS6 heads and 90/90? if so then I say absolutely.
Old 05-17-2006, 07:56 PM
Hennytime's Avatar
speed density tune will help a bit out too probly make it idle and drive even closer to stock than a maf'ed 224
Old 05-17-2006, 08:56 PM
slimcracka's Avatar
afr 205s lol
Old 05-17-2006, 09:26 PM
BADSS's Avatar
Thumbs up
I made 420 RWHP with a TR 224, FAST 90/90, and JPR S2 LS1 heads.
I would hope your TSP heads would be worth at least 10 HP over my old JPR heads- which became notorious for flowing much less than advertised.
Good luck!
Old 05-17-2006, 09:33 PM
Redneck Z's Avatar
Lots of people have made that kind of power with those mods. There was a thread in here awhile back and there were cars in the 415-430+RWHP range with 224 cams.
Old 05-18-2006, 03:12 PM
2000 Tran Zam's Avatar
i made 425 rwhp and 408 rwtq with a 224 cam, stage 2 katech heads through pace setters. That was before my current setup though.
That was with a 78mm lsx intake and s3 throttle body, so with 90 mm intake/tb it should make at least 5 rwhp more or so.
Plus my a/f was at 12.3, so im sure I could have done it if we leaned it out a bit too.
Old 05-18-2006, 04:24 PM
Camaro ChriSS's Avatar
I made 420 rwhp (see sig) in an A4 not locked - so yes.
Old 05-18-2006, 08:48 PM
BriancWS6's Avatar
If you don't gain 33+ rwhp from heads and FAST 90/90 setup somethings wrong. I think you'll hit that no problem. Post back with the results man!
Old 05-18-2006, 09:48 PM
Red Hawk's Avatar
You can see a dyno chart on this thread: 430 rwhp, 410 tq
https://ls1tech.com/forums/convertible-vehicles/497742-dyno-tuned-my-vert-today.html
Old 05-19-2006, 11:20 AM
HAULNTA's Avatar
It will be close with those heads.
Old 05-20-2006, 06:00 AM
Phil'sC5vette's Avatar
im hoping for 410-420 rwhp after adding my AFRs in my sig
Old 05-20-2006, 07:19 AM
Brian2001SS's Avatar
https://ls1tech.com/forums/showthread.php?t=497742
Ahhh, thats my graph. The tune is what put me there, but I also have stock rear with stock gears. I noticed you have a bigger rear. But you should be close if the tuner knows there stuff.
Old 05-21-2006, 09:04 PM
02SOMWS6's Avatar
With a 12 bolt rear,denny's nitrous ready driveshaft, and H&C (224/228) I put down 426. Since then I have switched from SLP LT to Stepped Kooks, stock firehawk cat-back to a 3" X-pipe, LS6 intake to a Mamo ported Fast 90 intake with a 90 NW TB,injectors,fuelpump,fuel rails, and some other stuff. So I know I'm over 440rwhp so it can be done with the right matched parts
Old 05-21-2006, 10:19 PM
'Trust''s Avatar
Good luck!
Uh huh I have your heads on my car and did well thru a stalled auto.
Old 05-21-2006, 10:51 PM
BADSS's Avatar
Thumbs up
Yep, I guess those heads weren't so bad after all. Also made 400 RWTQ on my car, which was real impressive.
Old 05-22-2006, 03:23 PM
Ryan02SS's Avatar
420rwhp thru cats and 3 year old Patriot 5.3's. The cats dropped me 9rwhp when I was cam only vs ORY. A portmatched F90 and ORY would put my setup up about 20+rwhp.
