Vengeance Racing FINAL results on 440 stroker!! Graphs/details INSIDE
Specs on the combo are listed below:
LS7 BLOCK
Callies 4.100 Crankshaft
Callies "CompStar" Rods
Diamond Pistons
HellFire Rings
TrickFlow 235cc Cylinder Heads
Cometic .040 Gaskets
7.500 Pushrods
Vengeance Racing Custom Camshaft (26x/27x .595/.595 113)
Severe Duty Timing set
Ported LS2 Oil Pump
LS7 Lifters
ARP top to bottom
Compression 12.2:1
Supporting Bolt Ons:
VaraRam Induction
Stock MAF
LS2 90mm TB (Ported by Vengeance)
FAST 90mm Intake (Port Matched to 235s by Vengeance)
FMS 42lb/hr Injectors
ASP pulley
180* Thermostat
Mezierre Electric Waterpump
Kooks 1 7/8 LongTubes/catted 3" X pipe
Stock Z06 Ti Catback
Textralia OZ700 Clutch kit
Tuning by Vengeance Racing VIA EFI Live
Pump gas/Full Belts
The graph below is without the Ti Catback after final Tuning(Customer has ordered dual cutouts and wanted to know the power without the catback)
We decided to verify our dyno against another local dyno about 45 minutes away. The car was driven to the dyno/strapped down/and made the #s below. No cool down/ no tricks.... This dyno is known in the area to be VERY accurate/if not low at times.. It operates off of WinPep 6.03 Vs our WinPep 7
Pardon the dip in the graph above. I was driving the car and the dyno operator was controlling the sampling button. I let off the gas @ 6500 and he didnt quit sampling till a second or so later.... Im quite confident we could have picked up another 8 or 10rwhp/rwtq with a 10 minute cool down as the car was EXTREMELY hot after being driven 45 minutes in 90* weather
The graph below represents the engine through the Z06 Ti Catback Vs X pipe. Customer is ordering DMH dual cutouts and wants to see the gains through the free flowing exhaust...
I have several other graphs I will post if I can get time... Heads/Cam Vs 440... Modified LS7 Vs 440.. Stock Z06 Vs 440 etc etc.... I think our customer will be quite happy with his #s and Im sure he will get it to the track in due time.. Its hot as heck in Georgia right now so i wouldnt count on it for a few months!!!
LS7 BLOCK
Diamond Pistons
HellFire Rings
7.500 Pushrods
Ported LS2 Oil Pump
LS7 Lifters
ARP top to bottom
Compression 12.2:1
VaraRam Induction
Stock MAF
ASP pulley
180* Thermostat
Pump gas/Full Belts
I HIGHLY doubt the ARH headers would produce any higher #s than what this combo has already made.. The ARH Vs Kooks header fiasco is nothing more than speculation at this point... We have used Kooks for YEARS with GREAT success. They fit well and make excellent power...
FWIW, we did have one customer who ran ARH Longtubes on a 416 and the Y pipe choked the #s from 550 to 496..... Seems their Y pipe is a bit restrictive compared to others out there....
Just to be fair... If the guys @ ARH read this we will be glad to swap the headers and even retune if needed to see if in fact their product will make more power... Send us the headers
NOW, back on topic
NOW, back on topic
Originally Posted by JakeFusion™
Through Cats as well? I just noticed that. Very nice.
American Racing headers with a full 3" Borla exhaust would help push those numbers even higher. Either way, nice combo.
What's the price on this exact engine combo? PM if you don't wish to disclose. Thanks.
Super Hulk Smash
But that was with a Y-Pipe. I'd expect it to choke it down unless it merged into a single 4" pipe on something like this.
Wasn't trying to be an ***, but I've seen the catted ARH make more than the catted Kooks. Not a huge amount, but it's there. At this level, I'd figure removing the cats from any system would be worth a solid 10rwhp.
LS1TECH Sponsor
Originally Posted by Stang's Bane
The 609 is without the catback.
Nice results any way you look at it though.
Originally Posted by badpewter-z
for a z06 catback thats holding ton of power back
As you can see the 427 making 500 hp would require dual 3 inch exhaust, and with 600 hp it would need almost dual 3.5 inch. That is the problem with the Z06 catback. Now I know LG makes some adapters that bolt to their exhaust to allow a 3 inch catback. They are found under the C6 section and someone would have to fab a catback for a C5 to make it work.
IM CALLING B/S I WANT FUEL SAMPLES NOW.
RON, you sure are getting good with that photoshop!!
HAHA J/K Those are awsome numbers. I cant wait until we get another Weber/Trickflow/Vengeance combo out there. Problem with our guys is they run through autos that dont make big dyno numbers but really kick a$$ at the track!!
Dont worry brother... The track is where it is at... Unfortunately we just have a lot of street racers around here that dont hit the track as often as we would like.
damn, thats a stout combo. It really makes me want to slap some Trick Flow heads on my car bad. Oh Ron, i got my intake back and it looks good as hell. I will be putting it on this weekend and i cant wait to see the difference. Thanks Charles
