Weber Racing 408 dyno
Old 06-21-2008, 06:39 PM
lt1camaro95's Avatar
Default Weber Racing 408 dyno
I was hoping for 500 but I can't complain too much since it was dyno'd outside when it was 105 degrees.....in the morning. Damn its hot outside, anyway. The mods are listed in signature. It was done on a dynojet, I know different dynos read high or low, I have no clue how dynojets usually read.
480hp @ 6000
453tp @ 4700
Graph added 23 June
Old 06-21-2008, 07:37 PM
98blueSScamaro's Avatar
how is the vindicator with the 408
Old 06-21-2008, 08:21 PM
383ss's Avatar
what are the specs on the cam? i would have thought you'd be over 500 easy with that setup
Old 06-21-2008, 08:32 PM
I am sure if it wasnt so hot outside, the numbers would have been better. Probably re-dyno in the winter when we have nice 60 degree days instead of 115.
Old 06-21-2008, 08:35 PM
The extra cubes eats up alot of that duration. The max power is made at 6000 instead of 6700 with a stock cube motor. It cruises fine as long as I stay above 1300rpm or I get cam surge. But I have instant throttle response.
Old 06-21-2008, 08:36 PM
89Formulaws6's Avatar
not bad man but i thought you'd def be higher i dyno'd mine on a 85+ degree day on a mustang
Old 06-21-2008, 10:18 PM
lilbuddy1587's Avatar
I know all about dynoing in 110+ degree heat
Nice numbers! You've got me by 9rwhp and 7rwtq
Old 06-22-2008, 08:32 AM
beardWS6's Avatar
Your going to love the power. My 408 is pulls hard. Now spray it like I did and really see what happens!! My numbers in sig!!
Old 06-22-2008, 10:26 AM
black_z's Avatar
Temp/humidity are corrected for 99.9% of the time.....It could have been pulling a couple degrees of spark from the IAT temps though.
Old 06-23-2008, 11:00 AM
graph added
Old 06-23-2008, 01:31 PM
Originally Posted by lt1camaro95
graph added
Looks really good man!
Old 06-23-2008, 06:48 PM
Redlinez's Avatar
Nice, and it peaks right around 6000! That should be one nasty street car.
Old 06-23-2008, 09:54 PM
gametech's Avatar
LS1Tech 20 Year Member
What mufflers? That looks like one hell of a fun street car, but I'm thinking a TINY bit more power could be had. Of course, unless you are competing in a class, who cares? If you can hear yourself think at WOT, you have a good combo.
Old 06-24-2008, 12:18 AM
Bullets with true duals
Old 06-24-2008, 02:42 AM
BOWTIE's Avatar
Was the FAST ported? If not that would be my next mod. Porting seems to make a world of difference with those things to the tune of 10-35 HP. I would expect it to be worth the higher number on your setup.
Old 06-24-2008, 09:26 AM
Understand guys, here in AZ we "usually" don't see big numbers because of the ridiculous heat/dry *** air/shitty gas. We have a few months out of the year with some decently cool weather and thats about it. No doubt a ported fast would be a nice bump in power though.
Just for reference, a friends 402 with AFR 225s, FAST 90/90, full bolt ons minus EWP and a custom FTI camshaft put down right @ 500.xx RWHP and 47x rwtq.
Old 06-24-2008, 11:24 AM
But we get to have fun in the winter time while everyone else is parked in the garage.
Old 06-24-2008, 11:33 AM
thats why im hopen to move there in the next year and get out of the shithole michigan the state has too a dump on itself
