oil pressure issue.
oil pressure issue.
what could cause a oil pressure issue in a lq4 lost oil pressure and collapsed a lifter so put a new oil pump on and still is issue is not fixed. O ring is fine tube is fine
What do u mean a plug in the back of the block? If that's a sensor it can't be the issue because iam not getting oil to the top of the engine. I made a post on th issue in the ls1 internals forum
Time to pull the motor... I've had collapsed lifters before, but never went to "0" oil pressure. Sure it's not a spun bearing noise, plus the lifters rattling ? Either way, you're pulling the heads to get to the lifters.
