Eastern Members CT, DE, NH, NJ, NY, MA, ME, MD, PA, RI, VT, VA, WV
car repair question
Old 04-06-2007, 09:04 AM
STRIPSTAR's Avatar
Default car repair question
I changed the battery, alt and belt on a 02 Mercury sable. It now runs fine but the stupid battery light still comes on. Any suggestions?
Old 04-06-2007, 09:15 AM
Internet Mechanic
BlackScreaminMachine's Avatar
test the system with a volt meter it could be under or over charging
Old 04-06-2007, 09:46 AM
STRIPSTAR's Avatar
I did check that. I will check it again. i test from the Bat lead on the Alt right?
Old 04-06-2007, 10:02 AM
thingthatgoes's Avatar
You can test the voltage from any direct voltage source. The Bat. terminals would be fine. Whatever you could get to.
Old 04-06-2007, 10:24 AM
STRIPSTAR's Avatar
I already changed the alt twice to make sure it wasn the new alt. i also had it tested. all checks out. There must be some other electrical component that im missing.
Old 04-06-2007, 10:57 AM
jond99's Avatar
Before you go ripping apart your car, clean and reclean all connections and retighten everything, also check all your grounds and make sure they are solid.
Old 04-07-2007, 06:29 PM
TNTramair's Avatar
Dave....is there a voltage regulater?
Old 04-08-2007, 07:38 AM
STRIPSTAR's Avatar
Thats what im thinking but it looks to be in the Alt which is new.
Old 04-08-2007, 01:37 PM
TNTramair's Avatar
oh ok...i remember the older Fords it was seperate from the alternator...hmmm.
