Eastern Members CT, DE, NH, NJ, NY, MA, ME, MD, PA, RI, VT, VA, WV
The wait is almost over....
Old 07-15-2008, 04:34 PM
8ALTNG's Avatar
Default The wait is almost over....
After months and months of waiting for drag wheels, shop time and every other possible variable, the truck is almost there......
All the 10-Point pieces bent up and ready to be welded in
poor interior
these should work on the street
and these better work on the track....
Old 07-15-2008, 04:56 PM
DannoWS6's Avatar
Nice I can't wait to see what she does!
Old 07-15-2008, 07:02 PM
Race your car!
JL ws-6's Avatar
Looking good, what kind of raceweight are you expecting from it when you're all done?
Old 07-15-2008, 07:39 PM
My84Z's Avatar
Very nice!!!!
Old 07-15-2008, 08:32 PM
LS1Tech Sponsor
Slowhawk's Avatar
Heavier than before... It's a street truck.
Old 07-15-2008, 08:41 PM
Race your car!
JL ws-6's Avatar
I'm not up to speed on what the truck's weigh, I am sure the truck is capable of single digit power, I know all the turbo stuff and the cage can't be light though.
Nice project, there certainly won't be anything around like it.
Old 07-15-2008, 09:20 PM
LS1Tech Sponsor
Slowhawk's Avatar
Last year the truck made 1 pass then got kicked off. At 9lbs of boost launching off idle it went 11.3 at 120mph.We figure mid to high 10's at 9lbs then single digits at 14lbs. I think the truck weigh's 4600-5000lbs.
Old 07-15-2008, 10:16 PM
LS1TECH Sponsor
badpewter-z's Avatar
you must be getting itchy now matt
looks sick with the slicks stuffed in there
Old 07-16-2008, 04:17 AM
Race your car!
JL ws-6's Avatar
wow that's heavier then I thought.
Old 07-16-2008, 04:22 AM
Speedy0009's Avatar
Looks good Matt. Can't wait to get to to the track I bet as mentioned above the itch must be terrible.
Wow.. didn't think the short bed, single cab weighed that much...
Old 07-16-2008, 07:59 AM
8 second mod
Noyzee's Avatar
i like the way the rear is all tucked up, looking good.
good luck. looks like with some push you will be ready just in time for the good weahter
Old 07-16-2008, 09:41 AM
bgblockelcamino's Avatar
that looks awesome. good luck with it.
Old 07-17-2008, 03:31 PM
8ALTNG's Avatar
itchy doesnt even begin to describe it.
Old 07-17-2008, 06:08 PM
KevinF56's Avatar
sick dude. just sick. move over blacksheep.
Old 07-17-2008, 07:36 PM
8ALTNG's Avatar
Not yet.....
Old 07-19-2008, 07:04 AM
8ALTNG's Avatar
the engine assembly is heavy and there is a lot of **** in the cab. Plus the big front street tires, all the tubbing for the 10-point and my fat ***, it adds up quick
Old 07-19-2008, 07:17 AM
Race your car!
JL ws-6's Avatar
How does the cage work with a pickup, I have seen them with the bars that go thru the rear wondow (will now be a lexan window right?) but where do the tubes attach, to the bed or to the frame? Knowing the way pickup's are constructed with the cab being mounted seperately from the bed I always wondered how that worked. Without attaching to the frame I wouldn't think the cage would really add any rigidity to it.
I'll have to take a good look at how it's done next time I see a truck done up. I know a guy that wants to do an lsx swap on a newer s-10, and was talking about a rollbar for it and whatnot because he wants to be able to run it at the track, but I have no idea how that is done on a truck
Old 07-19-2008, 07:20 AM
LS1Tech Sponsor
Slowhawk's Avatar
Cage has to be welded to the frame.
Old 07-19-2008, 07:21 AM
8ALTNG's Avatar
it attaches to the frame. If you do a search over on PerformanceTrucks.net and look for black sheep you will see how it is done
Old 07-19-2008, 08:24 AM
Race your car!
JL ws-6's Avatar
I'll have to look that up. SO they put a hole in the bed to run to the frame then, and the cage in the truck is mounted to the frame the same way I take it.
I guess once that's on there, there's no more removing the bed or the cab from the truck frame anymore... intresting.
If your truck is gonna be in the 5000 lb range, what would an extended cab S10 with an alum block motor probably weigh in at? Guy knows how fast he wants it to do, I just have no idea what it's gonna weigh so I can't give a guesstimate as to what the power needed to get there will be.
Quick Reply: The wait is almost over....
