Florida Members Fun, sun and LS1's
rebuild or replace lt1 engine
Old 09-01-2010, 03:54 AM
monster of kuwait's Avatar
Default rebuild or replace lt1 engine
hi guys
i just bought a camaro 1996 z28 convertible with lt1 engine and after few days the engine is blow up so what should i do
should i replace it or rebuilt it or sell it
the car is so clean it looks like new
and what is the cheaper
and do you know good and cheap place to fix it around Tampa?
thank you
Old 09-01-2010, 04:12 AM
firebird99's Avatar
depends on what you want to do with it 1.you could always rebuild it it stock 2.do some searching for cheap used parts and stroke it and put some nice heads 3.just do a ls swap
Old 09-01-2010, 04:21 AM
no i want stock one
and how much will cost to swap it to ls
Old 09-01-2010, 04:55 AM
corvet786c's Avatar
Get the Latest LS1 or LS2 or LS3 engine you can. What a big diffrence if you can fit one in yourcar.
Old 09-01-2010, 05:09 AM
[QUOTE=corvet786c;13808260]Get the Latest LS1 or LS2 or LS3 engine you can. What a big diffrence if you can fit one in yourcar.[/QUOT
i do not have a big budget for that
Old 09-01-2010, 05:58 AM
98z28bitcha's Avatar
Just rebuild it if budget is not much room for ls1 swap. May have to bored over if use the factory block. I would see if anyone was sellin a used lt1 befor you start tear into the stock lt1.
Old 09-01-2010, 06:24 AM
do you know how much will cost
Old 09-01-2010, 04:40 PM
I have no idea I never had a lt1 but i did have a tpi 350 rebuilt for about 600 bucks. With new heads and cam which is a deal so it ranges. I know were your comin from.
Old 09-01-2010, 04:46 PM
camar0corey's Avatar
I would check on the cost of a rebuild. Its hard for me to recommend buying a used LT1, as the last TWO used LT1's I've received from the Tampa Bay area have been bad. Its hit or miss, I bought a used motor from a member on here that has been great for two years already, but then I've also had some duds.
Old 09-01-2010, 04:50 PM
blk/slvr02ss's Avatar
There is a guy around my area selling a 93 Z-28 for $1000 and it also comes w/ a LS-1.
Old 09-01-2010, 05:29 PM
Damn i would jump on that if i wasn't so broke.
Old 09-01-2010, 05:40 PM
Says the car needs a head gasket but he will throw in a LS-1 if u buy the car for $1000.
Old 09-02-2010, 12:57 AM
take a look for this deal it has warranty for 90 days seems its good deal
http://cgi.ebay.com/ebaymotors/ws/eB...ht_3524wt_1008
Old 09-02-2010, 05:20 AM
Damn for that I would put in a ls 6.0 truck motor.
Old 09-02-2010, 08:28 AM
For a pricing reference I paid $1900 shipped for a 15K miles 4 bolt main motor, with forged rods/pistons, hotcam, and longtubes. I wouldn't pay $1300 for a 96k motor! You could get your shortblock freshened up and assembled for $1k or less and be way better off, so long as a reputable shop did the work.
Old 09-02-2010, 08:36 AM
4u 2 nv's Avatar
$1300 seems VERY HIGH i agree...i was going to ask 2000 for my 79k mile LT1 with ALL acc, harness, and a t56 with new spec 3 clutch and ALL swap hardware.
and i also agree with whoever said do a 6.0 setup..those can be found SO CHEAP.
Old 09-03-2010, 04:58 AM
firebird99's Avatar
I found my lq4 (0.60)375 with forged pistons and arp bolts and studs fully balanced and assembled with custom cam for 1200 on craigs list fort meyers.Then i got c&c ported 243 ls6 heads from patriot performance on craigs list space coast with everything brand new unassembled for 650.A few weeks later i got a 90mm fast intake for 600 on the board so for 2450 and some drive time i have a pretty good lil motor so keep searching and you will find something
Quick Reply: rebuild or replace lt1 engine
