TC78 single or twins
Old 10-17-2008, 02:54 PM
trey04gto's Avatar
Default TC78 single or twins
On a 370ci LQ9... I already have one TC78 that I purchased from Jose at FI's and it looks like just running 2 of them would be easier to fabricate up. (using flipped C6 LS2 manifolds)
How long would spool time be running the 2 78's on that size motor?
Guess I just want some opinions on me running 1 vs 2 of these.
Old 10-17-2008, 03:00 PM
LS1Tech Sponsor
hellbents10's Avatar
It likely wouldn't make boost till about 5500rpm. If twins is what you want for packaging I would opt for twin tc61's with .68 ar's as they are the same physical size. Should be good for 1100fwhp or so in that form.
Old 10-17-2008, 04:41 PM
trey04gto's Avatar
Make any boost at 5500 or full boost at 5500?
Old 10-17-2008, 04:49 PM
LS1TECH Sponsor
DrTurbo's Avatar
Full boost around 5200-5500 rpms.
Old 10-18-2008, 10:37 AM
sciff5's Avatar
I'm not expert but if you want this to be a street car and have a nice powerband.. your better off going with smaller turbos. If its a track machine and you already have one of them then **** it, go big or go home.
Will spool like a supra with a big single, but there are lots of tricks available that the import guys have been using for a while to spin huge turbos.
Old 10-18-2008, 05:10 PM
BlackySS13's Avatar
Ive got a tc76 on a 370 and it starts boostin at 3200 with full boost by 5K. I would do one. If I was gonna do twin 78's, I would want a lil more cubes.
Old 10-18-2008, 07:37 PM
trey04gto's Avatar
So, twin TC78's would be one laggy bitch in other words... Well maybe not on a 408 or bigger but for now they would. I guess its back to the drawing board. Doing a single front mount on my GTO appears to be a pain in the ***!!
Old 10-18-2008, 08:42 PM
sciff5's Avatar
that sounds like some pretty slow spool compared to what dr.turbo claims
If it takes till 5k to get full spool with a tc76 I'll get something else
Old 10-19-2008, 12:21 AM
trey04gto's Avatar
I agree completely!!! I thought that the full boost by 5200rpm was something I was willing to deal with until I could build a 408 but damn. If your single 76 spools at 5k, I would never see full boost...
Old 10-19-2008, 01:41 AM
Johnv's Avatar
Something doesn't sound right with your setup !
My TC78 on 346 starts makeing boost under 1800rpm and is fully spooled (12psi)around 3k.
You need to check your manifold and flange gaskets for leeks as well as wastegate , and Intercooler pipes. your 370 should spool stupid fast !
What AR houseing are you running ?
Old 10-19-2008, 11:35 AM
BlackySS13's Avatar
My bad fella's, it's been a hectic last couple of days for me. Let me rephrase, because I meant full boost in that 3200-5k range depending on psi. On my 370, it starts spooling almost immediately...and at 2500 it is comin in...with full boost depending on psi usually at 3200 to 3800 on street tune and a lil higher for the race tune. Sorry for the condusion.
None-the-less, the tc76 spools super fast and is a great street turbo with some track potential too.
Old 10-19-2008, 11:42 AM
BlackySS13's Avatar
As a side note, on my truck, you are never NOT is boost under WOT, or even half WOT.
Old 10-20-2008, 05:04 PM
sciff5's Avatar
Thats impressive! Are you on stock heads?
How much power are you making at 12psi?
Old 10-20-2008, 09:34 PM
acidrain088's Avatar
bump for curiousity also what ar is that
Old 10-21-2008, 05:25 AM
Johnv's Avatar
Didn't get a very accurate reading on the dyno 550 rwhp, as it kept smoking up the tyres , conservative tune 11.5 AFR and 12 deg timeing , no meth.
stock motor , baby cam,valve springs and pushrods
exhaust houseing is a .96 ar
I have a forged 383 going in shortly, then i'll crank it up and bolt it to a hub dyno
Old 10-21-2008, 06:41 AM
BlackySS13's Avatar
Do you have meth? I would look into it, it's works great when crankin the wick.
Old 10-21-2008, 09:25 AM
sciff5's Avatar
How bout your hot side setup, what exhaust manifolds/ cross over tubing diameter and DP size? What size tubing on the cold side? I thought the TC78 spooled a little slower than the TC76 and you are getting that sort of spool characteristics with the Tc78 then I see no reason to not go with a tc78 unless you are really on a tight budget.
Old 10-21-2008, 10:14 AM
Gingervitis Addict
slow67's Avatar
I'm pretty sure a TC76 and TC78 are the same price new.
Old 10-21-2008, 12:01 PM
LS1TECH Sponsor
DrTurbo's Avatar
Correct
Old 10-21-2008, 01:42 PM
Johnv's Avatar
I have a shorty header on one side, 2 1/2" crossover and 2" on the manifold side.
3" dowpipe into single 3 1/2" exhaust
Cold side is 2 1/2" on turbo side(will be upgradeing this shortly) and 3" on TB side .
Have a meth kit to go on with the new engine.
Honestly the TC 78 .96AR t4 spools a little quiker then my old MPT70 1.0AR devided T4.
Quick Reply: TC78 single or twins
