Turbo flow: inlet reducer vs changing compressor
Old 11-19-2008, 03:00 PM
7 Second Club
Phil99vette's Avatar
Default Turbo flow: inlet reducer vs changing compressor
Has anyone tested to see the flow difference between lets say a 95mm turbo with a 76mm reducer and a true 76mm turbo?
Old 11-19-2008, 03:40 PM
LS1TECH Sponsor
DrTurbo's Avatar
Talk to Jose...they have done it. Creates one heck of a vacuum on the comp wheel from what I understood.
Old 12-16-2008, 06:43 PM
crashly's Avatar
will better be a ball bearing turbo..
or it will pull the thrust clean out of it...
nearly like a blocked aircleaner in front of it..
ash
Old 12-16-2008, 07:17 PM
LS1TECH Sponsor
DrTurbo's Avatar
ash
That is correct, and also pulls the oil through the front of the turbo....not good.
Old 12-16-2008, 08:15 PM
BoostnTBSS's Avatar
I have seen a Gt47-88MM with a 72MM sleeve i think it lasted a season and was used on a streetrace car and had good luck with it
Old 12-16-2008, 11:58 PM
Louis's Avatar
Its similar to an inlet restrictor on an LMP car or FSAE car. Airflow up to the sonic point will be greater IIRC.
Old 12-17-2008, 08:08 AM
nuclearxp's Avatar
Silly idea here - but I've heard talk about inserting inlet vein guides before the compressor. I think some turbodiesels do this. Maybe a properly sized/vein oriented guide could serve as enough restriction while still giving the added benefits of increased compressor outlet velocity?
Old 12-18-2008, 02:10 AM
chuntington101's Avatar
some people HAVE to run them! the WRC teams have to run a 34mm restrictor on their 2.0ltr turbo engines. same gose for the GT stuff...
are there really an advantages??
Chris.
Old 12-18-2008, 11:04 AM
Louis's Avatar
you can see the inlet restrictors on this Audi R10 Diesel LMP engine. They have to run 39.8mm inlet restrictors x 2 IIRC, its a GT30ish style turbo in flow rate.
Old 12-18-2008, 11:22 AM
Louis's Avatar
http://forums.vwvortex.com/zerothread?id=2444259
Old 12-18-2008, 11:54 AM
Shearer's Avatar
TR30R = sex. And expensive as hell too.
Old 12-18-2008, 12:05 PM
jfg455's Avatar
sometimes I read posts and realize that I am indeed dumb. Should have listened to dad and did better in math!
Old 12-18-2008, 12:53 PM
Frank02L's Avatar
A 95 reduced to 76? I've seen some GT47s in "76" format. Do you have to actually measure across the tips 76mm or just an inlet reducer?
Old 12-19-2008, 01:56 AM
bloody hell! i have seen those cars close and personal (insade of a lovely sweeping right hander on gravel) and seed engine bay pics before but my god that manifold looks good! and that turbo looks amaizing to. and they are running V-band flanges.....back in 2001!!!!
Louis you should see how fast these things go form breakling HARD fora corner to full on the throttle. i bet there is NO lag! and i really mean none! i have seen them do standing starts on gravel (no traction, all 4 wheels spinning) and they are still making BIG boost. i hear 15psi is made with no load on the engine!!
no maybe you could mod the APS kit on your Corvette to run this type of anti-lag!
Chris.
Quick Reply: Turbo flow: inlet reducer vs changing compressor
