Speed Inc TT 1992 Typhoon build
Old 11-30-2008, 08:50 AM
danimal95's Avatar
Default Speed Inc TT 1992 Typhoon build(final assembly pics)
I recently bought a 92 typhoon from texas,ultra solid truck,and decided to yank the 4.3 and throw in a iron block LS1.It will retain the AWD,A/C,power steering as well as the rest of the creature comforts.The motor is a 402 built by one of our engine builders,the heads are E.T 245's,custom Speed Inc hydraulic roller cam,plus the rest of the typical engine upgrades
The turbo system will be built by me and will include a set of GT35R's with the tail stainless housings,as well as 2 precision air/water intercooler cores with hand fabbed end tanks.
The trans is a FLT 4L80E with the George Blake H.D. imput shaft and the ST/TY performance adaptor for T-case.I will be hanging a Ford 8.8 rear end with a hand fabbed 4 link set-up and disk brakes,the front brakes will be C5 disks and rotors.
I was able to pull the motor and get started on the LS install last week,the oil pan started life as a 07 Escalade pan but by the time I got finished clearencing it you would never know,the motor mount are staight forward pieces welded directly to the cross member.I will post more picks as the progress goes along,here are some from last week,the first is the truck as i recieved it,here is a link to the build progress pics:
http://s439.photobucket.com/albums/q...mal95/typhoon/
my goals are mid 9's on DR's without any compromises in drivabilty or comfort
Old 11-30-2008, 09:14 AM
renzos23's Avatar
Awesome truck. Sounds like its gonna be a beast.
Old 11-30-2008, 09:51 AM
2nd fastest 5.3 ECSB
trever1t's Avatar
Man that looks clean Looking forward to reading more on the build!
Old 11-30-2008, 09:58 AM
Tiago's Avatar
cool project
Old 11-30-2008, 10:48 AM
MIGHTYMOUSE's Avatar
here you go
good luck to you, definitely not a drag and drop swap!
if any of your friends really like it put a good word in for me, still trying to sell mine.
Old 11-30-2008, 01:29 PM
danimal95's Avatar
thanks guys,GMHT is documenting alot of the swap,so watch for more on it in upcoming issues
Old 11-30-2008, 03:26 PM
Sideways240sx's Avatar
Very cool project. good luck.
Chris
Old 11-30-2008, 03:31 PM
2thousand2's Avatar
I actually like the wagon wheels on that thing! looks factory!
Old 11-30-2008, 04:13 PM
02SSLE's Avatar
going to be badass
Old 11-30-2008, 04:45 PM
danimal95's Avatar
yeah the wagon wheels definatley fit that truck better than the C5's, however it will be on grey C6-Z06 wheels when finished
Old 11-30-2008, 07:27 PM
6 Second Club Moderator
LASTLS1's Avatar
Nice looking Dan!! I can't wait to see it finished.
Old 11-30-2008, 07:49 PM
Coal Mining Director
onfire's Avatar
Killer project Dan. Mid 9's with GT35's and traction will be cake. Good luck on the build.
Old 11-30-2008, 08:35 PM
qqwqeqwrqwqtq's Avatar
Looking forward to seeing some AWD burnouts
Old 12-11-2008, 06:23 PM
danimal95's Avatar
more progress has been made the motor and trans are in the final position as well as all the accessories,including the a/c which was kept in the stock LS location,lower pass of engine.it was a challenge getting it to fit,i really didnt want nor could afford the space lost if i was to use a high mount unit.i had to take minimal amounts of the frame out,which will be boxed in.i had to use a trailblazer ss a/c compressor,it was the shortest and the thinest unit i could find.it still required me to make my own mounts for the unit itself and for the tensioner,im quit happy with how it turned out,and was considering having the brakets reproduced if any one would be interested.
the fabrication of the turbo system should be started next week,im just waiting for the turbos and intercoolers,to arrrive fron exile turbo,2 garret GT35R's and 2 garret 1000hp a/w cores,it appears that these headers will be the easiest that i have built and i expect them to be done by the end of next week
here are the pics:http://www.fquick.com/garages/GMC/Typhoon/1992/25691/
__________________
Old 12-11-2008, 07:30 PM
TTV8Typhoon's Avatar
Looks really good. When I first started my project in 2005, I wanted to keep the A/C in stock location but noticed that it was into the frame and decided to do a high mount. Now I regret not sticking with the low mount.
A turbo LS Typhoon is fun!! I was the only green/gray LStt.
Nice color combo on the TY!!
Old 12-11-2008, 08:48 PM
danimal95's Avatar
thanks,sweet set-up,have you ran it?what are some of your build specifics?
Old 12-12-2008, 10:03 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
Yeah Dan's truck will look great in GMHTP, it's very clean.
Old 12-12-2008, 12:19 PM
prochargedchevyi's Avatar
I love the concept. I bet it's going to turn out great!
But holy moly that oil pan is super close to the differential! Is that the final positioning or are you going to notch it somehow?
Old 12-12-2008, 12:25 PM
stock LS1 long block,T04B's with .69A/R turbines, fabbed headers, Air/Air in old heat exchanger area, 60lb injectors, Big Stuff 3, 4l80e with 2600 stall, Qa1 coil over front suspension, baer brakes, Racepak for gauges.
No track or Dyno yet.
Chris
Old 12-12-2008, 01:22 PM
danimal95's Avatar
thats the final position,its close but there is about 1/8" which from my experiance is plenty
Quick Reply: Speed Inc TT 1992 Typhoon build
