Incon twin kit question!!
Old 01-15-2009, 03:38 PM
o2ws8's Avatar
Unhappy Incon twin kit question!!
Well i have An incon twin turbo kit on my car and I recently rebuild the turbos like 4months ago.The other day it started smoking and I look underneath and I see oil dripping down of my passenger side turbo.The driver side is fine but for some reason this passenger side turbo is giving me hell.I have oil dripping out of the blowoff valve on that side.Could the seals have gone bad already?Or what could my problem be? If anyone can help me out I gladly appreciate it.
Old 01-15-2009, 04:07 PM
Pat-Man's Avatar
Did you personally rebuild them or did a shop?
Old 01-15-2009, 05:01 PM
o2ws8's Avatar
A shop in houston called turbochargers!
Old 01-15-2009, 05:03 PM
Pat-Man's Avatar
I'd take the turbo (or whole car) back to them and have them look at it. Maybe something wasn't put back together right, or not tightened correctly.
Old 01-15-2009, 05:06 PM
o2ws8's Avatar
Well all they do is rebuild turbos and sell them they dont actually work on the car.A shop in houston was the one that worked on my car!
Old 01-15-2009, 05:08 PM
Pat-Man's Avatar
Talk with whomever rebuilt the turbo. They more than likely have some kind of warranty for their work (30-day, 60-day). I'd start there first. If they tell you to shove off, then get back to us. It's not normal for turbo seals to go out like that after a fresh rebuild, unless they didn't assemble it correctly. Also, make sure your oil feed and return lines are all tight and its not leaking from them.
Old 01-15-2009, 05:11 PM
o2ws8's Avatar
Naw I think its the turbo cause I have oil leaking out of my blowoff valve and on the airfilter pipe on that same side.I even have oil leaking out my cutout!
Old 01-15-2009, 11:14 PM
Louis's Avatar
turbo drain problem.... restriction or kink in the drain line.
Old 01-15-2009, 11:20 PM
myfast70's Avatar
Damn, you beat me to it.
Did you make sure that the restrictors got re-installed (if there were any to begin with)?
Old 01-16-2009, 01:04 AM
Qwick98Z's Avatar
+2 on the drain problem. I have done 7 incon kits and have replaced more tilton pumps then I want to think about. I replaced them with a wedon and added "check valves" and the cars never had problems.
Old 01-16-2009, 08:19 AM
o2ws8's Avatar
I have pics ima try upload them today so yall can see how the lines are ran! Uploaded!
Old 01-16-2009, 01:45 PM
o2ws8's Avatar
I dk if this pics help any!
Old 01-16-2009, 01:55 PM
Pat-Man's Avatar
Wipe off the surfaces and get them clean the best you can. Then get the car on some ramps, start it up, and see if you can find where its coming from. If your turbo is leaking from one of the seals, you should see it as soon as you get oil pressure. Make sure its not coming from somewhere else. It could be leaking from someone else, and gravity is just doing its job (causing it to run down the lowest point of the turbo and pipes).
Old 01-16-2009, 02:01 PM
o2ws8's Avatar
I already did and as long as I dont turn on the the car it wont leak .once I turn it on it starts leaking out of the crack on the turbo and it drips down!
Old 01-16-2009, 02:04 PM
Pat-Man's Avatar
Then it has to be the seal. I'd take it back to whomever rebuilt the turbo. They obviously didn't tighten the bolts to spec or didn't clean the flange surface during the rebuild.
Old 01-16-2009, 02:09 PM
sevanseriesta's Avatar
can you tighten the bolts and see if it helps, they were loose on my car tightened them up and no more leaks after that!
Old 01-16-2009, 02:13 PM
Pat-Man's Avatar
I'd personally take it back to the shop that rebuilt them. If you mess anything up, than that is all on you. Have the shop fix their screw up. Just my .02
Old 01-16-2009, 08:54 PM
cablebandit's Avatar
lets see the pic of the air intake hose to that turbo...is it smashed in half against the kmember?
Old 01-16-2009, 09:11 PM
o2ws8's Avatar
Not sure!I had a guy tell me that My drain line is out of place and that I should rotate both the exhaust housing and compressor housing so the centersecion(with bearings and oil drain) is pointed straight down
Old 01-17-2009, 06:15 PM
barnat's Avatar
Default oil pump
Ide check the oil return pump VERY GOOD or replace just to be on the safe side .Thats why i made a belt driven system for my INCON before i sold it for a APS Heres a few pics if you havent seen it yet
http://i243.photobucket.com/albums/f...arparts006.jpg
Quick Reply: Incon twin kit question!!
