Just Completed 2000 TA Maggie Install!! Dyno numbers!!
Old 01-22-2009, 06:23 PM
martinls1's Avatar
Default Just Completed 2000 TA Maggie Install!! Dyno numbers!!
Let me tell you, I can't believe how much time it took to install this thing! Took me 2 FULL weekends to get done! I bought this kit used off another member here, this kit is the one from Late Model Speed.
Check out the throttle cable bracket, I liked how MTI does there setup, flipping the throttle body upside down, so I just fabricated my own bracket(still have to paint it). Looks clean, right?
I had it tuned at Masport yesterday, let me tell you, the car is unbelievable!! I've never had a car have so much power! And the whine of the charger, priceless.
Let me know what you think of the numbers?!
Only mods to the car are:
Hooker Headers
Magnaflow exhaust
TR224 cam
Dyno numbers!
Pictures of setup!!
Old 01-22-2009, 06:34 PM
Customizing Director
MadIceV8's Avatar
Very nice
Old 01-22-2009, 06:37 PM
cbr600rx7's Avatar
+1 i had planed on running the LMspeed kit before going to TTI. Looks good man.
30th t/a's Avatar
real nice. some heads would you way over 500rwhp. how much boost & whats your compression?
Old 01-22-2009, 06:39 PM
MY99TAWS6's Avatar
Gotto to love that torque curve.
Old 01-22-2009, 06:41 PM
outtacontrolz28's Avatar
Nice numbers man...like that setup
Old 01-22-2009, 06:48 PM
martinls1's Avatar
Yeah, it took awhile to get the wifes blessing on this, heads are in the plans or if the rear end takes a dump first..........
the boost is from 7-8 lbs
Old 01-22-2009, 08:54 PM
code4's Avatar
that's some crazy low end torque. congrats
Old 01-22-2009, 09:24 PM
elias_799's Avatar
is this on a stock shortblock ? if it is try to save some money for a forged shortblock just in case this one goes. you should be fine for a while if you have a good tune. also some lq9 heads would help you out allot. your CR would be lowered to somewhere around 9.5:1 depending on the gaskets you use. good luck
Old 01-22-2009, 09:58 PM
boysiner's Avatar
Any videos?
Old 01-22-2009, 10:01 PM
Firebirdfan's Avatar
WHAT a torque curve man....That's almost as flat as the ZR1 dyno (just not as high, lol). VERY impressive.
Old 01-22-2009, 10:46 PM
TripleWhite96's Avatar
Nice car man! I saw it as I dropped my turbo formula off..Dan was moving it as I got there. Cool to see it on here and too bad I didn't see ya as I was there. made good power and nice to see another boosted fbody around here Nice work man!
Old 01-22-2009, 10:47 PM
Braunbeck's Avatar
What were the numbers prior to the Maggie?
I'm torn if I go FI, the roots based scare the hell out of me being in such a hot climate, I can get a Procharger for about the same price and pick up a water/meth kit for protection in the hotter months.
Old 01-22-2009, 11:49 PM
LilJayV10's Avatar
Good lord look at the torque curve!
I am torn between a maggy or a single turbo. I love the sound of the maggy.
There was some talk in MTI's thread that dropping the compression ratio with this type of setup may not be a good idea because the blower can't deliver enough boost to over come the drop in compression to make it worth it. That's the way I understand it. If someone else has any input please do.
The only thing I am worried about with this setup is heat soak or high IAT's.
I would give up several horsepower to have the sound.
Get a video so we can hear it!
Old 01-23-2009, 02:07 AM
SStolen's Avatar
I'm curious as to why you think LQ9 heads would help out so much.
Old 01-23-2009, 02:12 AM
LSONE's Avatar
It probably wouldnt "help" per se, but the lower compression would make it a lot easier to run a solid tune on in hot and humid florida weather.
Old 01-23-2009, 05:00 AM
venom ws7's Avatar
Very nice numbers on Mustang dyno and sick TQ curve.
Poor Tires.
Old 01-23-2009, 09:21 AM
Monello's Avatar
looks nice! I miss my magnacharger that I had on my grand am =-(. The sound that thing made at 5k RPM while racing on the highway will always be missed.
Old 01-23-2009, 07:19 PM
martinls1's Avatar
Yes!
The only other time I had my car on a dyno was before the LS6 Manifold and TR224 cam, and the numbers on a DynoJet were 356 hp and 360 tq. at the wheels!
Unfortunately, I wasnt able to be there when the car was on the dyno. But I will be shipped a video of it a little bit later.
And get this, after just a couple of days of driving the car, I just found out that I need to key the crank! I just found that the crankshaft pulley was half off tonight. How hard is that to do?
Old 01-23-2009, 07:38 PM
TS6
TS6's Avatar
Its easy, buy one of the fixtures from ATI or EPP, makes it an easy process.
Quick Reply: Just Completed 2000 TA Maggie Install!! Dyno numbers!!
