anyone boosted a high mileage motor?
Old 02-01-2009, 12:42 PM
99345hp's Avatar
Default anyone boosted a high mileage motor?
Just like the title says, has anyone added FI to a high mileage motor? How did it work out for you? I know it is probably a bad idea all together, just curious if anyone has had any luck with it.
Old 02-01-2009, 12:55 PM
subarubill96's Avatar
condition of the motor is more important than mileage. leak down test and compression check it. if you like what you see, boost away if not rebuild it for more boost. the tune will be your saving grace, if its good you can go on for a long time with no issues. i think most failures are more user related then mechanical anyway.
Old 02-01-2009, 01:41 PM
quicksilverado's Avatar
I had a s/c on a 5.3 from 40k-120k and then put a turbo on it after that. It finally blew at 190k. When I tore it down it looked great. Went lean and lost a piston.
Old 02-01-2009, 04:45 PM
99345hp's Avatar
I need to do a compression and leakdown on my car to see how it looks. It runs amazing, and doesn't burn much oil at all. Uses 1 quart in 5,000. Always used synthetic oil. Im looking at a used vortech sc that was installed in a transam for a few thousand miles.
Old 02-02-2009, 04:31 AM
EPP
EPP's Avatar
http://www.exoticperformanceplus.com...Car.php?car=55
I bought my '99 Z28 back in '02 with 110,000 miles on it. We put a ProCharger D-1SC on it, and at 125,000 miles we upped the boost to 15 psi for the hell of it. It lasted longer than we thought it would and it saw some street use and made the rounds of several different dragstrips. Bob
Old 02-02-2009, 06:19 AM
99345hp's Avatar
15 psi on a stock bottom end at 125k? I guess that shows the durability of the LS1. Thanks for all the responses.
Old 02-02-2009, 06:35 AM
TECH Cry Baby BOSS APPROVED!
Urban Legend's Avatar
Go ahead and run 15 psi on the stock bottom end. Start searching for a shop that will rebuild your engine.
Old 02-02-2009, 08:50 AM
pwrtrip75's Avatar
My junk yard 5.3 probably came out of a 100k+ truck. 15psi and a 50 shot on it going on 3 years...and still running like a dream. But engines dont travel miles so mileage is meaninless. Who knows if the engine came from a truck with 4.10 gears and did nothing but haul heavy loads or if it came from a highway cruiser? I have a vette with 150k miles on it and it runs and drives like new. Mileage is a form of measurement to use for warranties...thats about it. My Transam has 120k on it and has already had the engine rebuilt, tranny rebuilt and on its 3rd rear end.... so what does mileage tell ya?? Not a damn thing.
Old 02-02-2009, 10:05 AM
TripleWhite96's Avatar
Granted I just got mine done for the most part its a 90K motor on 5-6lbs but it is taking it well..though looks like the PCV system is enjoying to lay oil all over the engine bay, thats the only fix to come so far
Old 02-02-2009, 03:15 PM
NXSLT1's Avatar
Put a roots on my LT1 at 150K at 7-8 lbs. Only problem I have now is blowby. I fix one hole that it's blowing out of and it finds another.
Old 02-02-2009, 04:20 PM
98Camarod's Avatar
Mines doing the same damn thing. i didn't use any oil pre turbo, now there's oil everywhere. What are you planning to do? I've got 83k on mine.
Old 02-02-2009, 06:02 PM
elias_799's Avatar
just make sure your engine is not making any ticking sounds on the bottom end. mine has 135k and i will be throwing a turbo on there in a couple of month. good luck
Old 02-02-2009, 06:07 PM
elias_799's Avatar
and if you want some more safty for your shortblock get some 317 heads (heads of an lq9 or an lq4) gm mls head gaskets, better valve spring to prevent valve float, harder push rods, dual roller, high flow oil pump, upgrade the fuel pump to a walbro 255 at least, arp head studs. that is what i have, i just need to make some time to install it all.
Old 02-02-2009, 06:14 PM
ForcedInduction's Avatar
140,000+ here on a T70 Fed 5.3 Bone Stock,(except ls6 cam and springs) heads never been off. Ran all last summer at 10 psi, with a couple runs as high as 14 psi. Added Meth and Nitrous over the winter and tuning up to 15psi.
We got another 5.3, an LS1 and an LQ9 on the backburner Just in case....
Old 03-05-2024, 07:06 PM
boostedc6GS's Avatar
What points did you get blowby at?
Old 03-06-2024, 10:07 AM
Rainz/28's Avatar
Just a heads up that guy hasn't been on the site in over two years. I would do a search on LT1 and blowby, and if you don't find what you need start a thread. I would imagine first would be to check to make sure your not pressurizing the crank case as boosted cars will do.
Old 03-08-2024, 05:36 PM
mOtOrHeAd MiKe's Avatar
Location: Ottawa Ontario, Canada - where arguing "DA" is for the slow and weak...
D1SC on my 240K km TBSS' LS2. So there's that...200K+ miles on the LS1 in my wagon on the bottle. And countless other junkyard engines that get boosted too.
The quality of tune will kill the engine before forced induction does.
The following users liked this post:
ddnspider (03-20-2024)
Old 03-09-2024, 09:41 AM
Old Buzzard's Avatar
Lightbulb Maybe...
Take a look at the Sloppy site.
They've been doing that for years.
Old 03-13-2024, 02:23 PM
Full Power's Avatar
I took an old take out 4.8, came from a high hours work truck: 2004 I think... Unknown miles, but PLENTY of'em paid $600 for the motor.
Put on a Magnuson TVS1900 at 11 PSI, drove it through half of Canada, to Texas and back, the LONG way ( 10,000 miles in 21 days.) back in 2017.
On the Texas trip, I ran 7000 miles 'til oil change, 6 quarts came out CLEAN in a NAPA parking lot around Ashland Oregon.
It's been a regular driver since, no problems. I drive it HARD all the time, and oil consumption is as close to ZERO as I have ever seen.
After 4000 miles, of regular commuting I will have about a shot glass of clean, slightly milky oil in the catch can.
6 Quarts goes in, and I drain damn near 6 quarts out.
around 221,000 miles on the Tahoe now. 4.56 gears, so the little 4.8 gets PLENTY of revolutions- haha.
............................short stroke likes SHORT gears.....................
Old 03-20-2024, 09:48 AM
mk3cn4's Avatar
GEN III's are iffy I think because of the weaker rods. Otherwise I think they are about the same as the GEN IV 24x reluctor.
For what it's worth for future searchers, my prior L33 was 150k engine from a junkyard $500, had a slight knock when cold- should have returned it but didn't, DD drove for maybe 6 months and during a 14PSI pull it made the knock permanent (was a spun bearing I believe from prior owner not keeping oil clean/changed). On the stand now and will polish one crank journal and replace one bearing, everything else still looks great.
Current L33 is another ~150k $500 junkyard engine, has been doing fine in spite of me burning a hole in a piston during a low fuel pressure event at the track. Swapped piston while engine still in car using original rings and bearings and rod, still holding up at 10-12 PSI daily driving. Planning on turning up to 14PSI when track opens this spring.
Only modification for each was better valve springs to overcome boost. Nothing else touched.
I think as long as the cylinder bores look OK and "if" you can pull one rod cap off to inspect one bearing (try to not let the magic out!), I'd boost just about any high mileage factory built LS single digit PSI, even higher than 150k IMO.
Old Buzzard (03-20-2024)
Quick Reply: anyone boosted a high mileage motor?
