Steel J-Bracket for procharger... which company!?
Old 02-10-2009, 10:43 PM
BIG BAD BLACKSS's Avatar
Default Steel J-Bracket for procharger... which company!?
So I was looking into the steel J-Bracket and I see two company's mentioned while searching. Automotion which I haven't seen referenced for about 5 years, and this company that has one on their website.
Is one better then the other? Did they change company names?
Should I just order it here?
http://truetechperformance.com/page/...o-charger.html
Old 02-10-2009, 11:44 PM
conan's Avatar
Whats wrong with the aluminum one?
Old 02-10-2009, 11:47 PM
Rickys S/C Z28's Avatar
Flex.
Old 02-11-2009, 12:15 AM
'Trust''s Avatar
How much boost are you running? Seems like a crock to me. I'm sure there is SOME flex, but more from the spacers than the bracket itself.
Old 02-11-2009, 12:18 AM
im not seeing any flex in mine im just saying that why you would want a steel bracket
Old 02-11-2009, 12:21 AM
'Trust''s Avatar
Oh I agree on the reasoning behind it, I just don't see the bracket being what flexes. I see the spacers and bolts flexing before the supercharger bracket itself.
Old 02-11-2009, 12:23 AM
conan's Avatar
Thats what I would think too. Thats a serious piece of aluminum compared to the studs in the alternator and aluminum stand off nuts.
Old 02-11-2009, 02:43 AM
Seen a few posts of people saying it helped so I figured while I'm in ther eputting it all in may as well get the better one?
Old 02-11-2009, 04:50 AM
EPP
EPP's Avatar
I called True Tech last year to order one, and they didn't have any made at the time. They took down my info so they could call me once they had a new batch made up, apparently they never made any as they never called... lol I'd be curious to see if it helps. Bob
Old 02-11-2009, 08:29 AM
427's Avatar
I just bought one recently from True Tech, it seems very nice.
Kurt
Old 02-11-2009, 09:19 AM
kp
kp's Avatar
I had two SDCE setups, one with the aluminum and one with the steel bracket. I switched between them a couple times and there was never any difference I seen really.
With the stock 6 or procharger 8 rib where you have to tighten the crap out of the belt it may help some.
A little hint is to take the aluminum bracket and drill another hole and use an extra bolt to hold the blower on, you dont even have to countersink it. That really helps out the stock J-bracket.
Old 02-11-2009, 09:33 AM
Shawn @ VA Speed's Avatar
we make a steel j bracket for the f body cars,here a couple pics of the prototype we made a while back.the stands are also 4130 chromoly
Old 02-11-2009, 09:36 AM
TS6
TS6's Avatar
How much?
FWIW, a nice brace from the block to the J bracket will pretty much eliminate flex. Its cheap too.
Old 02-11-2009, 11:18 AM
Disturbed Bird's Avatar
Originally Posted by TS6
How much?
i would like to know
Old 02-11-2009, 11:53 AM
that looks bad ***!! how much for the bracket and cog set up??
Old 02-11-2009, 03:24 PM
TECH Cry Baby BOSS APPROVED!
Urban Legend's Avatar
The true tech bracket has served me well for many years.
Old 02-11-2009, 03:56 PM
93formto98T/A's Avatar
Nice Shawn, for some reason that looks very familiar...
Old 02-11-2009, 05:06 PM
'Trust''s Avatar
Is that bracket spaced out more than the factory ATI bracket? The cog looks quite a bit wider than my 8 rib pulley, and mine *almost* touches the alternator pulley as it is, if the blower came forward anymore it would be inside the radiator...
Old 02-11-2009, 06:24 PM
Yes, it's considerably further out than an 8rib setup. The whole assembly was purpose built for the cog drive.
Old 02-11-2009, 07:06 PM
The j bracket normally sells for 139.95,if i could get orders for 10 or more i would be willing to drop that down to 120.00,the assembly with the stands,and hardware is $400.00-the stands can be made for 6,8,10 rib belts as well as a cog setup.
Quick Reply: Steel J-Bracket for procharger... which company!?
