Those with aftermarket radiators.....
Old 04-07-2009, 12:19 PM
2002RamAir's Avatar
Default Those with aftermarket radiators.....
All of those with a turbo setup and aftermarket rad what did you do with the head coolant crossover tube? My after market rad has one bung on the cap neck for the overflow tank... What do I do with the other hose?
Old 04-07-2009, 01:45 PM
4SFEDZ's Avatar
i just got a fitting welded into my rad! it only cost me like 20 to get it done!
Old 04-07-2009, 03:41 PM
2002RamAir's Avatar
Im basically just wondering if it can be plugged?
Old 04-07-2009, 04:24 PM
4SFEDZ's Avatar
no dont plug it!
Old 04-07-2009, 04:54 PM
2002RamAir's Avatar
does it matter where the fitting is welded into the rad? where did you put yours?
Old 04-07-2009, 06:34 PM
4SFEDZ's Avatar
right under the overflow in the filler neck. look where it was in the stock rad
Old 04-07-2009, 07:20 PM
WS6HUMMER's Avatar
You want it as high up on the tank as you can get it but still below the cap.
Old 04-08-2009, 07:35 PM
98Camarod's Avatar
I think what he's asking is if you drilled and tapped or if you welded it. I think I'm going to drill and tap it and see if that is what's causing the overheating for me.
Old 04-08-2009, 09:14 PM
WS6HUMMER's Avatar
I welded a bung in fwiw
Old 04-08-2009, 09:19 PM
cablebandit's Avatar
i drilled tapped mine...
Old 04-08-2009, 09:46 PM
trans2000am's Avatar
i gotta get this done also i would of forgot to do this if i didnt see this post
thanks
guys lol
Old 04-09-2009, 07:55 PM
needaz28's Avatar
I machined up a fitting at work then had it welded on. I made it the same size as the stock hose. Don't do that. Lol finding a hose was a pita. Make it the same size as the line coimg off the heads.
Old 04-09-2009, 08:05 PM
Floader's Avatar
I stuck mine right under the neck on the radiator. But a friend of mine did a swap in an old truck and we tapped the top of the water pump, looks clean and works fine.
Old 04-10-2009, 10:48 AM
needaz28's Avatar
I would avoid tapping the rad. my griffin was very thin. I don't think you could even get 2 full threads in there.
now a water pump is probally ok, even the oil pan seemed pretty thin.
Old 04-10-2009, 11:03 AM
4SFEDZ's Avatar
ya my griffin was, in my opinion, too thin to tap. plus the rad shop welded it for 20buck and its done right!
Old 04-10-2009, 01:48 PM
looking at my radiator it looks like i dont have enough room to weld 4 this? what else can i do?can you guys post a pic of where you guys did this
Old 04-10-2009, 03:03 PM
tsx153's Avatar
The flat spot on top of the water pump. Take the radiator hose off of the pump stick a vaccuum in there and drill and tap it!! There is a thread on here with pics some where!!
Old 04-10-2009, 03:05 PM
98Camarod's Avatar
I drilled and tapped on the tanks about a half inch down. Much easier than trying to get someone to weld it since I can't weld. I just used some grease to catch the shavings and none got into the coolant.
Quick Reply: Those with aftermarket radiators.....
