quick question help please???
Old 05-19-2009, 10:26 PM
_916ls1z28_'s Avatar
Default quick question help please???
do you guys think i should still run the sway bar even though its this close to the hot crosspipe ??
Old 05-20-2009, 01:25 AM
calongo_SS's Avatar
I wouldn't.
Old 05-20-2009, 01:36 AM
DeltaT's Avatar
Wrap the crosspipe in header wrap or some of that Thermo-Tec insulating tape (on the swaybar side), no problems then. Easy fix and it will help spool faster too. It's not like those temps are going to make the swaybar lose its temper or anything, maybe damage the bushings over time.
Jim
Old 05-20-2009, 03:54 PM
the sway bar is that close to it in the air so when its on the ground would it lean on the crosspipe drasticly?
Old 05-21-2009, 04:51 PM
any on e else have any suggestions on what i should do
Old 05-22-2009, 12:23 AM
tisk tisk input needed hehe
Old 05-22-2009, 12:28 AM
LS1Silverado05's Avatar
Depends what you want the car for....Mostly straight line, then just lose the sway bar.... If you like the curves, you might want to re-do that section of hot-pipe.....
Old 05-22-2009, 04:29 PM
[QUOTE=LS1Silverado05;11637201]Depends what you want the car for....Mostly straight line, then just lose the sway bar.... If you like the curves, you might want to re-do that section of hot-pipe.....[/QUOTE
how much you guys think it will cost to re fab it so its couple of inches away from the sway ?
Old 05-22-2009, 11:04 PM
[QUOTE=_916ls1z28_;11640169]
Hard to say... it always costs more than if you could do it yourself... but it cant imagine it would be terrible to just get a little more room...
Old 05-23-2009, 02:29 AM
DeltaT's Avatar
I'd test it first by putting it down on the ground. That section of a swaybar doesn't generally move front-to-back at all, it twists while the bar stays in place.
Jim
Old 05-25-2009, 06:20 PM
thanks for the input i wount be hitting corners but will take trips on the free way
so ima try it with the sway on then see what happens
Quick Reply: quick question help please???
