Time to upgrade.
Old 09-11-2009, 04:55 PM
cbr600rx7's Avatar
Default Time to upgrade.
What is the best single turbo to run that can support 600 horses. I am running a TTI 60 trim kit now but cant make more then 451hp with the small turbo. This is a street/strip car and i want to keep the turbo as responsive as possible.
Old 09-11-2009, 05:03 PM
Johnv's Avatar
A Turbonetics TC76 or TC78 are the obviouse choices.
Old 09-11-2009, 05:23 PM
01Z28Camaro's Avatar
I made close to 600 on 10 psi in 103 heat. Need I mention boost drop off, this was with a pt67. I'd go with a 76mm divided.
Old 09-11-2009, 09:41 PM
cbr600rx7's Avatar
I keep hearing about guys making 600 on 67 trims but then i have people tell me that it might make 500????? You can see why i am a little lost. I dont want to go too big since i want to keep lag down to a minimal and i dont mind spending a little more for a better turbo since i hope this one will last me a few years.
Old 09-11-2009, 10:12 PM
subarubill96's Avatar
tc-76 or 78. lol its gonna feel laggy compared to that baby snail though. full boost at idle much?
Old 09-12-2009, 08:31 AM
LS1TECH Sponsor
DrTurbo's Avatar
A proper size TC76 will spool VERY fast for the power it delivers.
Old 09-12-2009, 08:50 AM
cbr600rx7's Avatar
LOL what is this turbo lag you speak of I love the 60 it is great on the street but when i started with the 60 kit i said i would never go over 500 to the wheels. Well times have changed and now its time for a little bigger.
Old 09-12-2009, 08:55 AM
i imagine the car is much like a 2g DSM, instant power but the turbo is way too small to make big power. you could always try a Mp-70 and see but i personally wouldnt go under a 76mm for a 346. they seem to be matched very well. wait til you want 600, then 700, hmm close to 800... it never stops lol
Old 09-12-2009, 06:10 PM
cbr600rx7's Avatar
Yeah tell me about it . I see a lot of different turbo's out there so where should i be looking to buy from? The 60 on the car now is a turbonetics.
Old 09-12-2009, 08:19 PM
go with a turbonetics tc-78 with ball bearings if you can swing it ($1499). the BB will give you a quicker spool but be able to give you the room to grow. otherwise id go with a journal bearing TC-76 ($999). forced inductions has both. how much you looking to get out of the car powerwise?
Old 09-12-2009, 10:29 PM
cbr600rx7's Avatar
I would like her to be able to support 600 on a forged bottom end. The end goal is to put the car into the mid 10s. Right now she is running low 11s with the 60 trim and stock bottom.
Old 09-13-2009, 11:03 AM
either one of those turbo's i listed will get the job done both HP wise and ET wise
Old 09-13-2009, 05:25 PM
cbr600rx7's Avatar
Thanks for the help. I will need to notch the frame and upgrade my IC at the same time but i hope this set up will last me a little bit
Old 09-14-2009, 01:23 PM
Tski's Avatar
Do you still have the 2" charge pipes? The 60-1 from Turbonetics? TTi was selling the street kits with HiFi 60s which had the 2.75" compressor inlet and the 2" outlet - not exactly a 60-1. Mine fell over at 460/550 rw at 12psi. Anything higher in boost just made heat. I've just upgraded to a 67mm and need to work out 1 issue before hammering it. I can tell you the slight difference in lag makes it more managable on the street but pulls much harder with 5 psi less boost on the top end. Feels at least 50 rwhp better.....I'll max out the 2-bar speed density tune this week and let you know how it goes.
forged with 317s, a turbo cam on 116 and an auto
Old 09-14-2009, 01:25 PM
Tski's Avatar
btw, you can fit a 76mm compressor in a 60 series housing. No need to cut the frame.
Old 09-14-2009, 02:34 PM
cablebandit's Avatar
I found a post on the old ls1.com from when I had that kit. I said I'd be happy with 450rwhp. If my current combo wont make twice that ill burn it.
Old 09-14-2009, 06:49 PM
cbr600rx7's Avatar
Well if you want to see the current set up in action take a look.
https://ls1tech.com/forums/forced-in...im-action.html
My transmission and rear end should be able to handle well over 700 horses with no issue but i like being well on the safe side so i plan on over building the engine a little bit as well and if later down the road i want to go a little higher i have some breathing room.
Old 09-14-2009, 07:19 PM
vipvegas's Avatar
pm me got my TC78 for 865 shipped to the door brand new..
Old 09-15-2009, 07:16 AM
cbr600rx7's Avatar
Thanks for the info thats not a bad deal at all. Why 317 heads over the stock LS1 heads?
Old 09-15-2009, 07:21 AM
smokinHawk's Avatar
lowers compression so you can run more boost at a given octane.
Quick Reply: Time to upgrade.
