Glad I decided to dump my wastegate
Old 10-20-2009, 04:02 PM
NightHawk's Avatar
Default Glad I decided to dump my wastegate
Since the wastegate dump tube didn't line up, I figured I'd just hack it off and vent right to atmosphere...and I'm sure as **** glad that I did. I couldn't believe how fubar'd the opening where it dumps back into the exhaust was, it looks like a freaking rat chewed the hole! Dunno how badly this would have affected performance, but I'm glad I found this before trying to use it. I guess that's the downside of the eBay method
Old 10-20-2009, 04:18 PM
z28boysteve's Avatar
That would have led to some boost creep! I hacked my WG pipe totally off my PTK kit (the original manufacturers of a good product but they stole peoples money and went out of buisness so now they are copied) but anyway the wastegate provision is only good enough for a 38 mm or so, way to small, put a 2" pipe on there and a big old Tial and you will be in buisness my friend!
Old 10-20-2009, 07:19 PM
NightHawk's Avatar
Sweeeet How long of a dump pipe do I need on the wastegate anyway? I made a short one out of the pipe off the kit but it's only 4"-5" or so. Will that work or do I need to take it out of the engine bay?
Old 10-20-2009, 07:25 PM
elias_799's Avatar
just get a nice carbide bit and open it up a little
Old 10-20-2009, 07:34 PM
XtremeDime's Avatar
Keep me posted, Im doing the same thing and we have the same kit!
Old 10-20-2009, 08:07 PM
NightHawk's Avatar
I actually did open it up because I'm capping it off instead of welding it flush in case I want to use it some time in the future.
Cool, will do man.
Old 10-20-2009, 09:02 PM
Restricted User
98Z28CobraKiller's Avatar
Mine has no tube. As long as it's aimed in a direction that you dont mind having a little carbon...
Old 10-21-2009, 06:57 AM
Super Slow SS's Avatar
Tube length on the dump tube is only relative to where you want the exhaust to exit, makes no difference in performance. Although too small of a tube or to sharp bends might cause creep.
Old 10-27-2009, 05:23 PM
MUSTANGBRKR02's Avatar
DO you have pics of how you capped it off? I'm debating on wether to weld mine or cap it off.
Old 10-27-2009, 06:40 PM
NightHawk's Avatar
Unfortunately I didn't take an pics of it and I just wrapped the downpipe. I ended up cutting the pipe off about 1" up. I cut slits in the remaining pipe down to about 1/4" or so from the downpipe, then bent the slits over on each other and welded up the seams. That way I can still cut it off and weld up another pipe to the dump location.
Old 10-27-2009, 07:54 PM
Did you re-route the wastegate or leave it where it was?
Old 10-27-2009, 08:49 PM
NightHawk's Avatar
I'm using the feed from the junction pipe as normal, but I'm using the pipe that I cut off as a dump pipe. Should end up somewhat like this, but I may end up changing that angle or taking it further downstream.
Old 10-27-2009, 09:36 PM
Broke EF's Avatar
If you have the ablity to weld and do some fab, why didnt you make your own kit?!?
Sean
Old 10-27-2009, 09:40 PM
XtremeDime's Avatar
Lazy, thats my excuse at least. lol
Old 10-27-2009, 10:03 PM
reamo04's Avatar
do you have pics of how the rest of the kit fits?
Old 10-27-2009, 10:08 PM
XtremeDime's Avatar
We have the same kit, for the most part it fits pretty well. Theres definitely a couple spots that need attention but its 500$ so its to be expected.
Old 10-28-2009, 06:33 AM
NightHawk's Avatar
Pretty much
But there's a big difference between stuff like that and welding up an entire setup from scratch...maybe now I might be able to do it but when I bought the kit, before I had any actual hands-on experience laying out a turbo setup, I don't think it woudla been possible.
Old 10-28-2009, 06:39 AM
NightHawk's Avatar
Nah, I've been lazy about taking pics on this project and I've got it off again to drop the k-member.
Like XtremeDime said, he's got the same kit and has a recent thread with pics. If you search his threads you'll find it, as well as Monello, Dean95Z28, 98Camarod, and Frost all have build threads with tons of good pics and info.
Quick Reply: Glad I decided to dump my wastegate
