rx7 5.3/TC78, 9 sec pass
Old 11-02-2009, 01:10 AM
skinnies's Avatar
Default rx7 5.3/TC78, 9 sec pass
Took my rx7 to the track today and hit one of my goals I've wanted for awhile. To drive there, run a 9 and drive it home, which it did, only tweaked the tune and aired down the tires. All passes were on e85, $1.99 gallon cheap fuel! I was leaving SUPER SOFT so I didn't hurt the rear end, only running 5lbs all of 1st gear(~75mph) and 11lbs in 2nd and 3rd. It's a 140k mile junkyard 5.3 with a homebuilt manifold kit with a TC78, th400 with coan 4000 nitrous converter, ford 8" rear end with a 3.00 gear. Car has less than $7500 total invested, I need to add it up, but probably closer to $6000. I want to give a big thanks to Maxxmitchell, I couldn't have done it without him.
1.669 60ft
6.540 1/8th
114.82 1/8th mph
9.93 1/4
144.71 1/4 mph
On a 5lb pass, leaving super soft again it went...
1.735 60ft
6.806 1/8th
106.79 1/8 mph
10.48 1/4
132.99 1/4 mph
Put it on the dyno on Saturday, made 408rwhp on 5lbs and 557rwhp on 11lbs with 19 degrees timing. On 10 degrees timing it made 515rwhp. Car still has a lot left in it on this budget setup.
Old 11-02-2009, 01:40 AM
PaulC's Avatar
144 mph!!!Insane man, im loving it
Old 11-02-2009, 01:42 AM
extremetoy's Avatar
wow any idea how much it weighs?
Old 11-02-2009, 02:01 AM
skinnies's Avatar
2560lbs with me in it
We've had it turned up to 14.5lbs in my buddies car, same motor/turbo so it should still have some left in it. Plus actually using high boost in 1st gear should help a lot(I used it on the street in the top of 1st gear).
Old 11-02-2009, 05:13 AM
Frametwista's Avatar
that jus goes to show u u dont need as much money as people on here esoecially to go fast if u told somebody from here how much it would have u they would have said 25k to go that fast alot of people r clueless many different ways to get it done all r not super expensive congrulations on the great run
Old 11-02-2009, 05:30 AM
skinnies's Avatar
I'd also like to point out the motor hasn't had an easy life, I drive it and beat on it quite a bit, before I got the motor it was in my friends 3rd gen with the tc78 getting beat on a lot(quite a few 160-170mph pulls). This weekend alone it's been wot at least 35 times I can think of off the top of my head so it's not like it's a one pass wonder and will blow up, it's not turned up and on the edge.
Old 11-02-2009, 09:26 AM
LS1TECH Sponsor
DrTurbo's Avatar
The TC series units rock. We have sold tons of them and they really will take a beating. Great #'s so far.....I see their is alot left in it as far as turbo is concerned.
Old 11-02-2009, 01:24 PM
gnx7's Avatar
9's the 1st time out with a soft tune/launch and on E85! That is awesome.
I was curious what you are running for a fuel tank/pump/lines? Doesn't E85 require a plastic tank?
Old 11-02-2009, 01:37 PM
skinnies's Avatar
Plastic cell, braided line/hard lines, two 255 walbro external pumps. It's actually the 2nd time I had the car out to the track with the turbo setup, the 1st time it made it 15ft and killed some teeth on the ring gear the very first pass.
I actually bought a T6 76 off here I was going to run next year, but I think I'm going to sell it and keep the TC78, I think it has enough to push me over 150mph without much problem.
Old 11-02-2009, 02:10 PM
skinnies's Avatar
http://www.youtube.com/watch?v=rpVTO5a2ItI Here is a video some random guy took Sunday when I was on the way to the track and he posted on the local kcsubaru forums asking who's car it was, lol.
Old 11-02-2009, 04:48 PM
LS1 SPEED's Avatar
nice results for a very budget combo
vid was cool
when did you take the LT1 out?
Old 11-02-2009, 05:42 PM
stumprrp's Avatar
HOLYYYY SHITTT
lol! sick car!
Old 11-02-2009, 05:47 PM
ssick1's Avatar
dammmmmm that thing is a monster!!!!
Old 11-02-2009, 06:02 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
I didn't know that you finally gave up on the LT1. Great job with the swap though. All you need now is a hood.
Old 11-02-2009, 09:48 PM
skinnies's Avatar
vid was cool
About a month ago, my buddy offered me his 5.3/turbo so we built a new kit and threw it all in my car. The lt1 went 10.28 at 129, best mph was 131, but it would go mid/high 1.4x 60fts. I might try to leave harder to see what it will do next week, just don't want to kill the rear end.
Old 11-03-2009, 08:56 PM
dark_02wrx's Avatar
Hey man. Im thinking bout doing a 5.3 fb but havent seen it done many times. Did you have to mod the oil pan and did u run into a complications?
Old 11-03-2009, 09:03 PM
skinnies's Avatar
I am running a truck pan, it hangs low which is why I raised the front end of the car back up some. I'm going to have a local welder modify it this winter as he has done it before to a truck pan.
Old 11-03-2009, 09:32 PM
LS1TECH Sponsor
DrTurbo's Avatar
haha, that dude was suprised....
Old 11-03-2009, 09:44 PM
8 sec potential, 12 sec slip
ChevyChad's Avatar
LOL gettin it done in a first gen RX7. Gotta love it
Old 11-03-2009, 11:01 PM
71 chevy's Avatar
hi, are you using a stock cam and stock heads?? that thing is moving. 144mph nice
also, with the 78, how is it on the street?
Quick Reply: rx7 5.3/TC78, 9 sec pass
