42lb duty cycle of 115% at only 0.5bar - possible?
Old 11-04-2009, 04:54 AM
Vetal's Avatar
Default 42lb duty cycle of 115% at only 0.5bar - possible?
I made few pulls after installing TC78 to my 383ci. It's non-intercooled as of now, at 0.5 bar. HPT showed that at 6000rpm my 42lb injectors are working at 115%. AFR was 10.8. Is this possible? What power I should be making then?? I thought I have no more than 500HP (crank), but apparently injectors shouldn't be maxed out then??
Old 11-04-2009, 07:42 AM
Coal Mining Director
onfire's Avatar
Very possible with 7.5 lbs of boost through a 383 at 10.8 : 1 AF.....that AF will really work those injectors.
What's the fuel psi? Boost referenced?
Old 11-04-2009, 08:56 AM
dschmittie1's Avatar
My 60# injectors are at 98% duty cycle with 14psi on my 347 and that is at 83# of fuel preasure at 6500rpm MY base is 58psi at idle with a boost referenced regulator.
Old 11-04-2009, 09:21 AM
onfire's Avatar
That matches my buddies LPE Vette. 15psi boost, 60# and 98-102DC at 6700rpm......80's are going in this weekend.
Old 11-04-2009, 11:35 AM
Vetal's Avatar
Stock pressure, stock regulator
Old 11-04-2009, 11:44 AM
Well I would suggest a Boost Referenced Fuel preasure regulator. It helps take your injectors further. But considering you have a 383 and I am assuming you will turn up the boost at some point get the 60lb injectors aftermarket rails and a BR FPR. When I got my procharger I sold my 42lb injectors right away and got 60's
Old 11-04-2009, 12:27 PM
Louis's Avatar
Oh yes, definitely out of injector, and potentially less fuel pressure with the returnless setup, not to mention the lack of a 1:1 FPR.
Old 11-04-2009, 05:48 PM
Vetal's Avatar
So does that mean that I might produce 550-600 crank HP?
I'm thinking more about some 96lb, to be able to run 850-900hp on ethanol... Or is it overkill?
Old 11-05-2009, 07:35 AM
lt170chevelle's Avatar
Yeah i was going to say maybe you otto go a little bigger than 60s ..my lt1 is almost maxing my 42lbers out at 10lbs and im only a 350...383 will definitely need more injector
Old 11-05-2009, 07:54 AM
Vetal's Avatar
I'm going to run on ethanol to be safer (less chance of detonation), so thinking about 96lb
Old 11-05-2009, 09:43 AM
Well I am making 676rwhp on 93 and Meth I have a Buddy with a Procharged C5 with a 383 making 770rwhp on 93 and Meth.
Are you talking about Running e-85? You will need a lot of pump and bigger injectors as e-85 requires more fuel.
Old 11-05-2009, 12:28 PM
Vetal's Avatar
Yes, E85. You think 96lb will not be enough for 900HP on E85?
Old 11-05-2009, 01:50 PM
Louis's Avatar
900 rwhp? Or FWHP? you would be nearing the end of the injector at 900 rwhp and E85. It all depends on pump size, base fuel pressure, and a lot of other little bits, but it should be damn close!
Old 11-05-2009, 01:57 PM
Sluggish's Avatar
All I could run was 8psi with my 42lbers also.
Old 11-05-2009, 06:40 PM
Vetal's Avatar
Was thinking about 900@fly, but might as well go for 1000... TC78 is rated at 1100, so maybe 1000 is achievable...
Quick Reply: 42lb duty cycle of 115% at only 0.5bar - possible?
