5.41@125 with a 1.24 60ft on radials with a APS kit on formula
Old 11-09-2009, 10:01 AM
AgFormula02's Avatar
Default 5.41@125 with a 1.24 60ft on radials with a APS kit on formula
Friday we mounted 275 drag radials on the car. Went to the 275 Drag Radial shootout and made it to the finals. Go .09 better on the tree, go .02 better in the 60ft, out of him nasty and then the car starts breaking up. Car goes around and then I almost caught back up with him.
We screwed ourselves by overlooking the overboost setting on the eboost. (Set at 18 pounds)
We hit it during a boost spike in the shift.
Not bad for the first outing in a heads up class.
We are fighting some issues on the upper end which caused us to loose MPH. I think we could have gone a 5.3X if we had the good MPH (128) like we had at Crandall last week.
Looking forward to be back soon and try to get that 5.3X slip.
Thanks to Cj for cutting some darn good lights all night long, James V, Johnathon, Ryan for time spent getting the car transitioned form a ET drags to a Drag Radial. We got just as good of a 60ft on the radials as we did on the 28-10.5 slick.
Old 11-09-2009, 10:21 AM
Mavmavv's Avatar
Very nice numbers. That 60 is insane!
Old 11-09-2009, 10:29 AM
SincalT/A's Avatar
Right on that's getin it for sure.
I will have have thread up in a few weeks on alittle R&D for the whipple that might interest you.There's more potential to it then most people are led to believe.
Old 11-09-2009, 10:52 AM
GueSS Who's Avatar
Car is hauling ***
Old 11-09-2009, 11:12 AM
Turbo LS1 SS's Avatar
Very nice. Care to share your suspension and gearing setup and launching setup?
Old 11-09-2009, 11:14 AM
cracker's Avatar
Looks like those tires worked out.
Old 11-09-2009, 02:01 PM
HUNTER02SS's Avatar
Nice times! Any vids this time??
Old 11-09-2009, 02:17 PM
BadgeZ28's Avatar
amazing short time. I hope you get the top end problem solved.
Old 11-09-2009, 02:33 PM
Silvy6.0's Avatar
Very nice numbers!!!
Old 11-09-2009, 02:36 PM
cablebandit's Avatar
awesome numbers.....I gotta go check my eboost myself now that you mentioned that
Old 11-09-2009, 03:42 PM
QA1 single adjustable shocks all around.
Wolfe Sway bar
Moser 12 bolt, 3.73 gears, 35 spline gun drilled axles
Launching at SP1 set at 7 pounds. Build boost before prestage, prestage,
as soon as we light up the second bulb we are on the TB that turns on the lingenfelter stutter box. Lights flash, and as soon as we let go of the TB we go to SP2 (12 pounds), then bring in sp3 (16 pounds) .5 secs out.
Thanks Wade. You saved the day!
Old 11-09-2009, 03:43 PM
Yes. Will et them off the camera soon. We did have a problem with the amera so they all look like night vision.
Old 11-09-2009, 07:24 PM
Lythropus's Avatar
Torque arm?
Old 11-09-2009, 08:32 PM
eb02z06's Avatar
Wow!!!!!!
Old 11-10-2009, 08:34 AM
Originally Posted by Lythropus
Torque arm?
BMR Adjustable TQ arm.
Wolfe LCAs
Wolfe Sway Bar
Quick Reply: 5.41@125 with a 1.24 60ft on radials with a APS kit on formula
