can I drill the merge collector, or just run two wastegates?
Old 12-03-2009, 12:55 PM
71 chevy's Avatar
Default can I drill the merge collector, or just run two wastegates?
guys, I need advice on this one.
this is what my merge collector looks like
is there enough meat here to drill a 1.5" hole for a wastegate pipe?
the alternative is to run a wastegate off each pipe. I have a tial 38mm and I can buy an ebay 38mm for around $60.
OR, can I run the wastegate off just one pipe???
what would you all suggest?
Old 12-03-2009, 01:07 PM
XtremeDime's Avatar
I would run just 1 WG at the merge. I would hate to run 1 tial WG and then an ebay one on the other side, I wouldnt feel comfortable with that. Dont run just 1 WG off 1 pipe, that will cause problems. Also why so much piping on the driver side pipe? What kind of manifolds did you use?
Old 12-03-2009, 01:11 PM
71 chevy's Avatar
thanks. Im thinking it would be easier and cleaner than running two wastegates, assuming it works.
I needed ample clearance for everything. control arms, alt bracket, and Im running a thick taurus fan...no space to run it straight. had to go down then come back up.
how about drilling just one pipe, but at the merge. would that work??
oh, ls3 c6 manifolds
Old 12-03-2009, 01:33 PM
yessir's Avatar
you want it at the merge ideally but many mustang kits mount the gate on one of the merge pipes with no issues but with that setup and a small gate you might have issues controlling high boost.
Old 12-03-2009, 01:36 PM
99LS6SS's Avatar
I would just drill it right in the center. You'll just have to form the flange for the WG to fit the cut you make when you drill it.
Old 12-03-2009, 01:38 PM
yessir's Avatar
on my setup i welded a pipe to the merge and mounted the gate ad the end of the pipe
Old 12-03-2009, 02:31 PM
Fondle's Avatar
ive seen people run two small pipes off of each side before the merge into a seperate merge just for the wastegate,
Old 12-03-2009, 04:54 PM
71 chevy's Avatar
thanks guys. Im just gonna put it right in the middle of the merge
Old 12-03-2009, 05:57 PM
Restricted User
98Z28CobraKiller's Avatar
I wish I had done 2 gates. First I tried to get away with one 44mm Tial but it wasn't enough. Now I have a piece of **** eBay 60mm gate that I have already paid $140 (2 tial diaphragms) worth of replacement diaphragms. So now I got $300 into this POS that still leaks air and still need to buy a real single for another $500+. My advice is do it once and do it right so you dont end up with a $300 paper weight when all is said and done, like me.
Old 12-03-2009, 06:07 PM
ninety4three4's Avatar
What pressure are you running at? Im assuming not crazy high? What spring do you have in them? Are you running any sort of boost controller on it?
Old 12-03-2009, 07:39 PM
Restricted User
Currently I can't get it down below 12 psi at full boost. No matter what spring I use. With the single Tial 44mm it was even higher. I'm not sure how high because it would just keep climbing and I would let off by 5K RPM and 15-17 psi in 2nd gear. I had a 7 psi spring in the tial and this one is supposed to be about the same. It's the lightest one that it comes with. I'm using an AMS500 boost controller with CO2 to increase the boost. I'm OK with it only going down to 12 psi. The problem is that it leaks the CO2 pressure so the boost fluctuates 2 psi or so throughout the course of the pass.
Old 12-03-2009, 08:02 PM
Louis's Avatar
Hmmm....somewhere in your build thread I remember saying just that One 44 isnt enough with big turbos!
Old 12-03-2009, 09:05 PM
71 chevy's Avatar
I'm using a 70mm unit. You don't think one 38mm is enough? What size turbo are you running with the 44mm gate
Quick Reply: can I drill the merge collector, or just run two wastegates?
