76GTS vs PT-88
Old 01-01-2010, 03:22 PM
355TurboLT1's Avatar
Default 76GTS vs PT-88
Curious what the difference in lag will be between a 76GTS and a PT-88. This will be going on a forged 355, PTK turbo kit (real one)A2W. I am in the process of deciding whether to keep the 76GTS and have it turned into a 80mm or go to the PT-88 which will require a bit of work as far as modifying my existing kit goes. The 88 will also allow me to reach my goal of 950rwhp. Thanks in advance.
Old 01-01-2010, 03:50 PM
smokinHawk's Avatar
Well I can compare a turbonetics 76mm to a pte88
the 76 hit 10psi at about 3k rpm while the 88 hit 15psi at about 4k
it sure didn't feel laggy just violent.
Old 01-01-2010, 06:39 PM
So it looks like the 88 might be the ticket. Are you running the pte88 in your car?
Old 01-02-2010, 10:49 AM
engineermike's Avatar
From what I've seen, the T88 makes equivalent power to a T76 at the same boost levels. Even though the compressor wheel is more efficient, the turbine wheel is old-tech and less efficient. However, then the T76 hits its choke limit, the T88 will keep on making power. The point is that you have to run a lot of boost/power for the T88 to shine.
IMO, check out the ST80. It has more efficient wheels in it than the T88 and is bigger than the T76, making it a better all-around turbo than either.
Old 01-02-2010, 03:14 PM
smokinHawk's Avatar
Yes Im using the pte88. Haven't got to turn it up quite yet only have used 15 psi but it wants more boost and rpm
Old 01-02-2010, 04:21 PM
TurboAv's Avatar
What RPM are you turning your engine to?
Old 01-02-2010, 04:33 PM
Restricted User
98Z28CobraKiller's Avatar
T88 or PT88? My PT88 breaths fire compared to the T76's that I have seen around here. It's not even in the same ballpark. I bought the turbo used. It was previously on my friends Grand National running 8.8's in the 1/4 at almost 30 psi. I've got it set at a solid 15 psi right now and expecting to see 9.3's Wednesday night when the track reopens.
Old 01-02-2010, 08:17 PM
smokinHawk's Avatar
It's a 347 spinning it to 7000-7200
it's hard not hitting the limiter as soon as I shift the tach moves and hits before I could hit the next gear. Switching to a th400 from the m6 now.
Old 01-02-2010, 10:17 PM
PT88. My car went 146 mph at 17 psi at full weight with a 76GTS. ForcedInductions.com did a back-to-back dyno test with the 76GTS and PT88, which is where I got my info. At 1000 hp, they were within 20 hp of each other, but the 76 was at choke and the 88 had more to go. The PT88 has an old-school turbine wheel.
Old 01-02-2010, 10:35 PM
Interesting although you rarely see the 76GTS even break 900rwhp.Come to think of it I never have. I was always under the inpression that was out of its reach. This is the main reason I want to go to the PT-88. I also looked into the 80mm upgrade which is claimed to bring another 100hp or so to the table. Im kinda worried about the street behavior with the PT-88.
Old 01-03-2010, 01:18 AM
Just a few data points. . .
ForcedInductions.com got 99x rwhp out of a 355 LTx/T76GTS and T56, then pulled 150.x in the quarter. They reported the turbo was max'd out and peaked at ~24 psi then dropped a few psi from there. My own car backed up these results with a 146 mph pass at 3750 lb and only 17 psi.
We built a 377 SBC, carbureted with a T-76GTS and dyno'd on an engine dyno. It made 92x fwhp and 1080 ft-lb. The highest we ran the boost was 18 psi, while the turbo is good for 20+ on that engine.
There are a whole slew of Supra's making 1000 rwhp +/- using the T76GTS. Granted, the 76 is a little more at home on a 3.0 than a 5.7.
Wolverine on turbomustangs.com is claiming 1100 rwhp using a 42-76, which has the same wheels as the PT76GTS. Axeman on the same site made 840 rwhp with the 76GTS through an AOD. Brent Davis made 880 rwhp with a PT74.
Mike
Old 01-03-2010, 02:59 AM
Mike- Great info. I was not fully aware the test results between the 76GTS and the PT-88. It sounds like the 76GTS is plenty capable. I might just send it out to Jose at FI to have it turned into an 80GTS. That way I won't have to run it past it's limits to attain my power goals. So are you still runnng a 76 on your car? How is the behavior on the street? My compression is right at 8.5-1 and I am using AI's 200cc heads on a fully forged 355. I plan to run meth as a precautionary measure. I would be happy with 900rwhp. If I dont have to go to a PT-88 that would be great. Thanks again for the results regarding the 76GTS
Old 01-03-2010, 10:24 AM
... So are you still runnng a 76 on your car? How is the behavior on the street? ... If I dont have to go to a PT-88 that would be great. Thanks again for the results regarding the 76GTS
No problem. The full specs on the 355 LTx that made 1000 rwhp are posted either here or camaroz28.com. Do some searching and you may be able to find it. It outlines the comparison between the 76 and 88, boost numbers, heads, etc...
The 76GTS is still on my old car but I sold the car. Street manners were great. I didn't spool on accident, but spooled up fast when you wanted it. I remember data logs showing less than 1 second to full boost. Keep in mind, though, that I was running 388 cid (which isn't even supposed to work with the 76GTS), so it spooled a tad quicker than 355 will.
Mike
Old 01-03-2010, 10:57 AM
Restricted User
What's the price difference between a new PT76GTS and a PT88?
Old 01-03-2010, 12:02 PM
Snyper's Avatar
I think they are within 100$ of eachother.
Old 01-03-2010, 06:19 PM
ohshixgoat's Avatar
I got the 80 gts on my car old school ptk air to water.. cant wait to see what she does...
Old 01-03-2010, 08:39 PM
Yeah keep us updated. The more I think about it I might just go the 80GTS route. That intercooler setup is pretty impressive. Cant wait to get mine done.
Old 01-03-2010, 10:22 PM
ohshixgoat's Avatar
I will I already just got one member on the 80 gts wagon..
Old 01-03-2010, 10:44 PM
TurboAv's Avatar
lol
Old 01-04-2010, 07:43 PM
Just talked to jose of forced inductions. They no longer offer anything for the 80GTS as it was discontinued. Oh well looks like its the PT-88 for me.
Quick Reply: 76GTS vs PT-88
