EPP Blower Cam owners inside!
Old 01-12-2010, 10:13 PM
LS1Tech Sponsor
Superman09's Avatar
Default EPP Blower Cam owners inside!
What length pushrods are you guys running?
Did you measure for them or just go by suggestion?
How is your valvetrain noise?
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old 01-14-2010, 05:48 AM
EPP
EPP's Avatar
We have found the standard 7.40 length to work in most of the applications we have done. Bob
Old 01-14-2010, 06:06 AM
LS1Tech Sponsor
Superman09's Avatar
thanks Bob. Wondering if anyone else has measured to find or try anything a bit different at all. How is the valvetrain noise with this set-up and 7.4's you guys have noticed?
__________________
Old 01-14-2010, 06:32 AM
OUTLAWZ RACING's Avatar
I use the 7.40 along with comp r lifters. The old comp r lifters lol, the valave train noise is like stock but with the rumble of a cam. I also use the patriot heads, Im sure the heads with the taller deck will require a different push rod. Oh and I use stock rockers lol
Old 01-14-2010, 06:35 AM
LS1Tech Sponsor
Superman09's Avatar
Did you measure at all for the 7.4's or just order and install? Thanks!
__________________
Old 01-14-2010, 06:41 AM
forcd ind's Avatar
my 7.4's were perfect, 225 AFR heads and a 6.0 iron block-i made up a stock lifter into a solid one for checking-i use Comp 1.75 rockers
Old 01-14-2010, 07:09 AM
LS1Tech Sponsor
Superman09's Avatar
thanks guys! I appreciate the info! Anyone out there running a stock motor?
__________________
Old 01-14-2010, 08:14 AM
Rickys S/C Z28's Avatar
i running a stock CI LS1 and the 7.4's works very well but IMHO its a touch to big of a cam for stock CI. plus i have stock 317s on my car othere the springs and retaners
Old 01-14-2010, 08:56 AM
LS1Tech Sponsor
Superman09's Avatar
with this experience, why do you think it's a touch too much cam? Obviously it has quite a bit of duration for a 346. Do you notice driveability issues or nothing down low and power only up high or what's the deal? Enlighten please as I was about ready to pull the trigger here on it! Thanks in advance!
__________________
Old 01-14-2010, 08:58 AM
josepy121380's Avatar
Hardened 7.4's here also.
Old 01-14-2010, 09:50 AM
the cam works great! make a ton of power mid rang and pulles like a bear op top, drives as good as stock with the right tune, i say it just a touch to big because my tunner says that i am not using it to it best. you will love it, but as you have stated earler in here you would make just as much power with a Z06/ls6 cam with out the smell.......but no lope
Old 01-14-2010, 10:00 AM
vipvegas's Avatar
7.4 would work my engine builder told be me but he said the 7.3's were a perfect match with the ls7 lifters and epp cam in LS1 at least in my setup.
Old 01-14-2010, 12:12 PM
LS1Tech Sponsor
Superman09's Avatar
straight up 7.300's? Seems like a HUGE jump from 7.400's.
__________________
LS1Tech Sponsor
Superman09's Avatar
Thank you! I LOVE the lope
__________________
Old 01-14-2010, 12:14 PM
vipvegas's Avatar
I think the 7.3's were to obtain the correct preload on the lifters.
Old 01-14-2010, 12:28 PM
me too!!!
Old 01-14-2010, 01:50 PM
Detroitmuscle's Avatar
I've got a set of 7.3s if you need them Jonny, but it seems 7.4 is what everyone is using.
Old 01-14-2010, 02:45 PM
vipvegas's Avatar
7.4's for stock LS1 lifters, 7.3's with LS7 lifters cause the cup on top of the lifter sits higher. And to stay in the desired range of preload that was exactly what I was told. Any body else?
Old 01-14-2010, 04:20 PM
Unstang's Avatar
Anyone running this w/ L92 heads?
Old 01-14-2010, 04:50 PM
LS1Tech Sponsor
Superman09's Avatar
Thanks Jeff, but I think I will just order up some 7.4's and give them a shot. If there is too much noise I will measure and go that route as they are easy enough to change. Thanks though! BTW, do you have a length checking tool?
__________________
Quick Reply: EPP Blower Cam owners inside!
