How much psi can you get from a harrop 2300 ?
HI guys
i have a harrop HTV2300 2.3 LITER PD blower (similar to a MAGNAR CHARGER)on a stock bottom end ls3
it is under driven at the moment making max of 10psi
im thinking of doing a forged lsx 454 and putting the 2300 on top
what i want to know is the 2300 good enough to give 10 psi on the 454 or even 7psi
harrop in the US say 17,000 rpm about 2.5 to 1
is about as fast as you want to go on the blower speed ? would you get any boost at all at that rpm from a 2.3 liter blower on a 454 ?? thanks for any info
man its only been half a day, i know im new here but im not new to forums give it a few days, most here have daily jobs, families n such, there's a shitton of knowledge here and it may take a little time to get a response.
The 2300 will pump enough air to see 10psi on a 454 if it has a crappy exhaust and isn't built right. It's more at home on a much smaller motor. You need to come up with a hp goal more than a boost goal. A TVS 2300 will make plus or minus 700 rwhp effeciently. If you're looking for a whole lot more power, you might be better served to find a bigger blower. Yes, it can make the bigger hp numbers. There are probably better ways to make those numbers though.
and no one see it LOL
mine is under driven making 10psi with a stock bottom end ls3 with cam headers and full 3" duel system
HI guys
is this similar to the tvs2300 because if so, someone put in a 434ci motor and couldnt get more than 6psi of boost through that supercharger. but then again, people like MTI racing made big power, but not only that, they made HUGE torque with a TVS2300 on a 500ci motor.
is this similar to the tvs2300 because if so, someone put in a 434ci motor and couldn't get more than 6psi of boost through that supercharger. but then again, people like MTI racing made big power, but not only that, they made HUGE torque with a TVS2300 on a 500 ci motor.
any info on the 500 ci motor what blower speed ?
I have used a HTV2300 on a built 454 with pretty good success.
I ran the Harrop 10PK pulley kit with the 3.071:1 ratio pulley set.
I also installed one of my "Dual-80" throttle bodies.
Peak psi was 14.5, & IAT's got to ~80C on the engine dyno & it pulled a little under 1000hp on pump fuel. With more tune time we would have cracked 1000hp - we only ran conserviative timing.
very nice bit of gear
when you say built 454 can you elaborate on that
lsx block ? pistons ?comp ? cam size ect
trying to get one built to take the 2300 but no takers yet
thanks
The increase in torque was not as great as I would have liked - typically 35-45 ftlb depending on application.
- LSX & ported/chambered LS3 heads
- Custom Mahle pistons (I think)
- ~9.5:1 CR
- 235/248, 115LSA
I did not have much to do with the engine build.
The HTV2300 was overdriven LOTS - 10PK at ~3:1 drive ratio.
