LMR APS Twin Turbo makes 1004RWHP!!
Just finished this 02 camaro. Car is equipped with a 402ci engine and APS turbo kit. Car put down 1004rwhp on 19lbs of boost. Enjoy!
http://www.youtube.com/watch?v=hsjFCNVpHG8
This is a very simple street car build. Engine is a 402ci 6.0l aluminum block with callies crank, callies rods, and wiseco pistons. Compression is at 9:1. Has L19 head studs, ZR1 head gaskets, and custom hyd LMR turbo cam shaft. On top it has a set of TEA Trick Flow 245's. We built the T-56 and installed a carbon on carbon twin disc RPS clutch, Moser 12 bolt rear end with 3:42 gears. Turbo kit is a complete APS kit with their upgraded turbos GT35's. We did not remove the air filters or exhaust for the dyno pulls. Car made 750rwhp on wastegate only(7.5lbs) of boost on pump gas. We put VP 109 unleaded in it and turned the boost up to 19lbs to get the 1004rwhp. We did not even let the car cool down for that pull. I think there is a little more left in it. Customer took the car for the weekend to put some miles on her and will bring it back in a week or so for the final tune and to hook up the nitrous plate kit! =P
