Max boost - min compression?
Building a pump gas, twin turbo iron 408. It will have all the good ARP fasteners and forged internals. The car will have beefed up auto and 9" ford rear. The car will be mostly street, but I want great drag potential with a tire swap at the strip. Shooting for 800-900hp at the flywheel on pump gas.
I'm trying to determine a good max boost - min compression combination. I don't want to o-ring the heads.
BTW, I tried a search, but it's tough finding specific answers sometimes.
Thanks.
Thanks.
Run a 9:1 CR with 10PSI of boost and you should see around 900 Crank HP with premium pump fuel. I've run 14PSI on pump gas with the plugs looking just fine. I'm 8.9:1 CR.
Make sure you have Turbos big enough to keep your back pressure down and your air flow up.
i would talk to a couple of sponsors on this forum to get an exact spec of the turbo that will work for you
forced inductions and modular turbo are a good start
I'd speak with Speed Inc. instead.
http://www.speedinc.com/turbo.cfm
They have kits they've developed ready for sale.
https://ls1tech.com/forums/forced-in...974-o-f-i.html
What are you trying to do to this guy?
WTF are you taking about ?
forcedinductions is a trusted sponsor on this site and no it is not OFI, i have no idea how you came to that
as far as the modular turbo comment, he does not need to build any cars, he is a turbo retailer, the reason i have suggested him is because he can work out what turbo will work best just by doing a simple calculation and get the guy in a proper direction
Yeah did a search for Forced inductions and came up with only one hit on here. I looked again with forcedinduction (one word) and found who you're talking about.
Lot's of good info there for sure. They have a bunch of kits they made. Should definitely be a good source.
Modular Turbo is currently building a kit. I dont see much on their website of previous builds and test mules. I personally believe you need to have built a few in order to truly answer the question of a potential custom turbo build.
kentucky turbo can give good advice too, along with several members on here, NavyDavidSS ran his with twins for a while, Tiago has a 427 with twin 76's, im sure a few other people can name more. modular turbo and Forced Inductions.com are also great places to start and both have givin great advice to a lot of awsome builds
