2 step help
2 step help
Alright im keepin my car six speed with the turbo, but am i under the right assumption that i can build boost with the proper 2 step? im cuttin 1.49 60's with my n20 now and i DONT wanna loose that with a turbo setup, but at the same time i dont wanna got th400. so please enlighten me on this 2step.
/noob
/noob
yup, 2 step will help you out greatly. You're already a good driver if you are cutting 1.4x 60's in a 6 speed, it's just going to take some trial and error with the turbo setup.
You shouldn't rule out a Th400 though. I found my car to be A LOT more fun with the TH400 and was a 6spd die hard. Turbos + autos are like peanut butter and jelly.
Restricted User
You shouldn't rule out a th400 though. I found my car to be a lot more fun with the th400 and was a 6spd die hard. Turbos + autos are like peanut butter and jelly.
ok cool ya im eventually goin th400 but, turbos and 6spds werent meant to be together on hwys and auto jus cant hold against 6spd w/gearing.
can u build max boost on a 2step 6spd setup?
but he's also on a 2 step, so he is building boost on the line as well. The trick with launching hard with a turbo setup is having boost on the line, and being able to hook just like any other setup.
A friend in college used a 2 step on his Supra. He eventually took it off because he couldn't hook. Granted they are very different cars but yes you can build boost with a 6 spd.
I suppose the fine tuning is a matter for your controller? For instance, my stock STI ECU can be 'taught' a launch control that builds boost with a lower rev limiter when in neutral, then once in gear it'll spin past 7k again.
