Collapsed a LS7 lifter
Old 05-15-2010, 11:00 AM
blazin's Avatar
Default Collapsed a LS7 lifter
Here is the setup rundown
370
forged
g5x3 114 cam
trickflow pushrods
patriot dual springs
twin turbo
ls7 llifters
I measured for pushrod length and everything but we burnt a wire and then pulled the valve spring and guess what a collapsed ls7 lifter. Any suggestions going for 900+ whp
Old 05-15-2010, 01:16 PM
355TurboLT1's Avatar
What is your seat pressure with the patriots? I wouldn't use LS7's in a 900hp motor. Morels all the way. Ls7 lifters are cheap IMO.
Old 05-15-2010, 10:24 PM
elias_799's Avatar
+1 for morels. my ls7's are not in the greatest shape aether after 6000miles. next time i am buying morels.
Cadillac lifters are another good option
Old 05-16-2010, 12:24 AM
Bullitt4110's Avatar
I had a Cadillac lifters break on me, around the roller just cracked and broke off. I know of quite a few people that have had them break. I am currently running the LS7's without issue but I am no where near 900hp lol.
Old 05-16-2010, 07:33 AM
98Camarod's Avatar
I've got the comp cam replacement lifters. They seem to be holding up fine. I haven't taken them out yet though.
They also sent me a free t shirt with my purchase
Old 05-16-2010, 08:05 AM
OUTLAWZ RACING's Avatar
Thought the ls7 and caddy are the same?
Old 05-16-2010, 08:57 AM
Dumb Ass Vette Moderator
ls1290's Avatar
I recently upgraded from LS7 to CTV-R lifters.
Nope. The LS7 are stable up to 7000ish RPMs while the CTV-R are stable up to 8000ish RPMs.
Old 05-16-2010, 06:16 PM
jeremym's Avatar
So are the LS7 lifters ****? I am building a TT 441 LSX using the LS7 lifters. Shooting 1100rwhp daily driven
Old 05-16-2010, 06:26 PM
Restricted User
98Z28CobraKiller's Avatar
I haven't had a lifter problem yet and I been in the 850-950 rwhp ballpark for a couple of years with different cams, cubes and power adders. Rev limiter set at 7400 RPM. LS7 lifters. What length did you come up with for the pushrods?
Old 05-16-2010, 07:40 PM
elias_799's Avatar
^^ you think people put to much preload on them ? and that is why they collapse ?
Old 05-16-2010, 07:59 PM
Restricted User
That's where I was going. I haven't seen one fail and we've been thru a bunch of motors over the last few years as a collective group.
Old 05-16-2010, 08:33 PM
elias_799's Avatar
^^ what sort of preload you give them ?
Old 05-16-2010, 10:42 PM
blazin's Avatar
7.3s with the decked block and heads milled. We were making 640 hp on a mustang dyno(750ish dynojet) at 12 psi spinning 6500. Had very few miles on them. Putting morels in. Jermey don't cheap on lifters its not worth risking.
Old 05-17-2010, 07:13 AM
really dident know that did u mean ctsv-r or ctv-r?
Pm me a part number.
Old 05-17-2010, 08:30 AM
Restricted User
I use this method. I copied this from a post by Shane at Thunder.
Here it is again in a nutshell:
1. Using the EO/IC method, get the lifter to the base circle of the cam.
2. Using a known length pushrod (7.400" is a good start with stock rockers) run the rocker arm bolt down to zero lash. This is easily done with your fingers "wiggling" the rocker, the point at which the "slack" is just gone is zero lash.
3. Set your torque wrench to 22 lb./ft. Tighten the rocker to full torque and count the number of turns it takes to get there. 1 full turn wtih a stock 8mm X 1.25 bolt is ~.047" preload as measured at the pushrod/rocker interface.
4. I normally shoot for 1 1/4 to 1 3/4 turns with stock type lifters like Comp 850's, LS1, LS7 etc.
For an example, if you use a 7.400" pushrod and come up with 3/4 of a turn, you will need at least .025" longer pushrod to get into range. If you end up with 2 1/4 turns, you will need one .025" shorter...
If the OP is running a 7.3 pushrod, then it shouldn't be excessive preload. If anything, that's too short of a PR on stock style lifters. The Morels are taller so they require alittle shorter PR. I run 7.35's in mine with the LS7 lifters. My heads are milled down to about a 61cc chamber (they were originally 65cc) and my block was decked a few thousandths.
Old 05-17-2010, 10:11 AM
ls1290's Avatar
CTSV-R. Brain fart on my part.
Old 05-17-2010, 11:44 AM
tirefryin_s10's Avatar
Got a part number at all?
Old 05-17-2010, 12:13 PM
ls1290's Avatar
Originally Posted by tirefryin_s10
got a part number at all?
88958689
Old 05-17-2010, 01:38 PM
speedracer5532's Avatar
I was running the caddy racing lifters and one failed on me and locked the cam and broke the timing chain and ended up bending eight valves. I have Morel lifters in my engine now. I think the LS7 lifter is better than the caddy lifter but I still think I would spend the money on the Morel lifters if I was you.
Old 05-17-2010, 02:28 PM
2001WS6Vert's Avatar
Morel link bars here. I don't want to dig into the motor again.
Quick Reply: Collapsed a LS7 lifter
