Blower cams?
Old 08-18-2010, 12:47 PM
02LS1ram's Avatar
Default Blower cams?
I'm going to be buying a blower cam soon n I would like to see what's out there on the market. I know the eep/ brute speed cam is a proven peice, and I'm leaning towards it. but I'm just trying to see what some others have used n how they liked it. thanks
Old 08-18-2010, 01:07 PM
dschmittie1's Avatar
I was using one of Comps LSR centri blower cams in my car with the D1. It worked really well not sure if it would clear the pistons on a stock motor.
However Mean94Lt1 over in the easter section is a stock short block 317 heads and Epp blower cam and he made 592 on 10 psi and no Meth. I coached him through making the right choices on the build the it turned out well.
Old 08-18-2010, 01:56 PM
edge04's Avatar
here are my specs. 222/230 .597/.600 115 lsa +2
Old 08-18-2010, 02:04 PM
Restricted User
98Z28CobraKiller's Avatar
What are the specs on your current cam?
Old 08-18-2010, 05:06 PM
02LS1ram's Avatar
I think I rember seeing your fs thread a lil while n that cam was pretty big. I'm trying to put together the right combo, but this is my first time w FI n I'm kinda still learning about it
Old 08-18-2010, 05:09 PM
02LS1ram's Avatar
228/228. 588/588. 111Lsa at 0.50
Old 08-18-2010, 08:24 PM
C5kid's Avatar
Check out the specs of my Speed Inc SC3 cam (in sig vvvv)
I am happy with it, nothing to crazy on lift, has a nice lope if you tune set the idle alittle lower then stock, was easy to tune.
I know another guy running the almost identical cam that is putting down some really stout #'s.
Old 08-18-2010, 09:56 PM
blue00ZZleeper's Avatar
I made the numbers in my sig with a Z06 cam. Its not really tuned for the meth either...I believe it was around 17*
Old 08-18-2010, 10:06 PM
02LS1ram's Avatar
what kinda numbers did u make w ur setup? got a idle video by chance.
Old 08-18-2010, 10:26 PM
WHPLASH's Avatar
I couldn't be happier with my LG blower cam in my sig. Its real similar to Bobs blower cam. You can't loose with either one.
Old 08-19-2010, 04:01 AM
C5kid's Avatar
my last dyno session I put down 573/498 w/ alot of belt slip.
I'll try to find a video of the idle, i think my blower drowns it out though.
Old 08-19-2010, 06:33 PM
farmdawg's Avatar
I used the Comp SC3 cam from Speed Inc in my maggied car, same specs as above, car idled like stock and tuned easily. It helped with the 545/550 numbers I got with a Vengeance SD tune and the car was my dd for over 2 years.
Old 08-19-2010, 07:29 PM
Customizing Director
MadIceV8's Avatar
I really like the specs on the Futral F7 camshaft and have seen some impressive results with it as well. (224/230 588/595 114+4) I purchased one that I still have laying around here, been lazy.
Old 08-19-2010, 07:54 PM
9sectruck's Avatar
comp. waiting to go in this winter 232 235 620 624 114+4
Old 08-19-2010, 08:27 PM
white01ss's Avatar
Very close to my PG/EPS cam. Slight lope, good vacuum, pulls like crazy up top.
Old 08-19-2010, 10:30 PM
02LS1ram's Avatar
I def want some thing w a pretty nasty chop too it
Old 08-19-2010, 10:41 PM
9sectruck's Avatar
big dur. split, idle tuning will start to get more difficult the bigger the split
that way you keep the lsa bigger
Quick Reply: Blower cams?
