jgs 60mm waste gate spring
i have three springs with the wg from jgs. One is taller and narrower than the other 2 that came with it. I get 7psi with that one, i turn the controller on and get 14-15psi. Can i put pne of the shorter wider springs in the wg with the tall narrow one to increase the boost. ive searched and couldnt find any real answers other than get a ams1000 with c02. im looking for 12 psi on the springs and 20-24 with the boost controller.
Restricted User
Really? The more boost you make the more it will push on that top port meaning the less you will bleed off. I would try adding a second spring instead. That's why one if smaller than the others. So you can run it inside the bigger one. Referencing the bottom port will help open the gate under boost. No reference at all will make another few psi.
i have a JGS 50mm with the low spring and i have a refernce going to both both ports. right now I make 13 psi.. i was thinking about running the Dial-A-Boost to the top port and running a reference from the manifold to the bottom port.
I used a line to the top port with a nitrous jet in it to regulate how much pressure it can put to the top port. This isn't on a jgs, but it should work. This allows me to go more than double the springs.(ie run 6lbs and 18lbs) I use a gm boost solenoid to switch to putting pressure on the top port vs just having it open. I also use a MBC on the bottom port to bring the bottom setting up some so I can get the top high enough to make over double. Also running another gm boost solenoid on the bottom side so I can run the spring pressure or the mbc setting. Kind of confusing, but I have 4 boost settings on the fly with 2 different buttons on my steering wheel which makes it nice on the street.
20psi to the top port+7psi spring=27psi holding it shut
add 7psi to the bottom(manifold reference) and you get the WG opening at 20psi. (just and example)
..I know that when you add boost pressure to the bottom, you lower boost pressure to the top.. so it will be a % instead of a number like 7psi. Im going to try it tonight.
my springs were the same diameter so i couldnt add them. They also mentioned shims to increase the pressure.
I purchased the large spring from them for my 50mm wg and now mine opens up at 10psi but i dont think it made a difference but i had my turbosmart boost T manual boostcontroller in series with the reference line although i had it set to send full pressure and not bleed any off
If u look on their site they list the thickness of the wire to determine if its the small, medium, or large spring
Restricted User
In your first post you said that you had 2 different diameter springs. Mine came with 2 diff diameter springs. 3 total. The piston design makes changing springs much easier than on a diaphragm style where you have to be careful not to pinch or tear it.
I run an AMS with CO2 so I run the lightest spring possible to give me the broadest boost control possible.
I guess that I misunderstood your post about bleeding off the bottom port. I thought that you were going to leave the bottom reference port vented. As in not regulating it with a controller of some sort.
Restricted User
Here's a cheap CO2 option for you. Buy a solenoid and one of the 10oz CO2 bottles with regulator and gages. Should be under $150 total. Regulate the CO2 down to where you want it and hook it to the noid. Then use your reference with the dial a boost to tweak it in where you want it. Just an idea. With the CO2, you wont need to wait for boost to make boost. Should help you get up on boost a little faster also if you need that sort of thing.
