241 casting heads and 20lbs of boost
Old 09-01-2010, 09:31 PM
0camaro1's Avatar
Default 241 casting heads and 20lbs of boost
I am building a 8.5 compression 370in LQ9 base motor. I am wanting to use my stock casting 241 heads witch i have had alot of work done to them ie 2.05/1.60 valves and alot of port work, with a good set of cometic head gaskets and head studs can i get away with putting 20lbs of boost in the motor with out pushing water ??
Old 09-02-2010, 11:34 AM
0camaro1's Avatar
Come on. No one has any info on this.
Old 09-02-2010, 11:37 AM
NoGo's Avatar
Maybe.
Turbo or supercharger?
Old 09-02-2010, 11:39 AM
0camaro1's Avatar
Originally Posted by NoGo
Maybe.
turbo car
Old 09-02-2010, 11:48 AM
'Trust''s Avatar
Ehhh, I dunno. They don't have a very thick deck. I'd be surprised if they stayed down.
Old 09-02-2010, 11:49 AM
NoGo's Avatar
I'm sure you will get a lot of conflicting opinions on this but... I think there is a good chance you will push a little water with that setup.
Old 09-02-2010, 12:09 PM
tirefryin_s10's Avatar
I have a 8.85-1 370 with ported 317 heads and I have been to 22psi a few times by accident lol and 19 on a regular basis, just make sure the tune up is right.... Detonation will lift the heads long before a straight up boost number will.
No water has moved in mine.
Old 09-02-2010, 12:52 PM
Max@Cartek's Avatar
We've gone to 24 psi and made 1016 rwhp with no issues. Not sure if that is what you are looking for.
Old 09-02-2010, 02:57 PM
0camaro1's Avatar
what head gasket were you using ?
Old 09-03-2010, 09:46 AM
Max@Cartek's Avatar
Cometic
Just realized this is for 241's, we did it with 243's. Sorry.
Old 09-03-2010, 10:05 AM
ArklaTexan's Avatar
hmmmm....this begs the question what can I do with my 370 LQ9 with AFR 225s with a thicker deck and ARP Studs?? I was thinking staying around 17, maybe I can go higher
Old 09-03-2010, 11:38 AM
0camaro1's Avatar
Cometic
are the deck thickness the same ?? being that they are both stock casting heads
Old 09-03-2010, 11:56 AM
fatmat80's Avatar
good question..
Old 09-04-2010, 12:35 PM
99SS-T's Avatar
I didnt know that any of the heads had thicker decks.
Since you are doing a LQ9 engine why not use those heads and not so big of a dish on the piston? Not that its huge but less dish is better for strength.
Im not sure but arent the 241's the 01+ ls1 and the 243 are the LS6 heads? If that is true arent the LS6 heads designed better with better flow. AND if THAT is true arent the 317 heads the same as LS6 heads but bigger cc.
What im gettin at is isnt the 317 heads better flowing? If Im wrong please educate me. I love to learn!
Old 06-22-2014, 07:17 PM
Emersan's Avatar
Interested, I know its an old thread... but any new info??
I was interested in running Ported 243 heads with 8ibs of boost...
Comments or concerns?
(Supercharger)
Old 06-22-2014, 07:41 PM
87silverbullet's Avatar
8 psi ain't nothing. You can run that on stock gaskets and head bolts all day.
Quick Reply: 241 casting heads and 20lbs of boost
