run it, it helps a lot with tuning, get a threaded one off of a GMC cyclone, it has the same connector as a ls1 and threads in instead of just a grommet
Close to the TB mine is about 4-5 inches in from of the TB. I spray my Meth about 8 inches in front of that so the computer sees the drop in IATs from the Meth
as close to the throttle body as possible so the sensor can see any heat soak or variance in the tubing temps, but YES YOU NEED IAT sensor, thats second most important sensor off a wideband
