Turbo cams: VA Speed vs Speed Inc vs Brute Speed vs LS9?
Old 09-15-2010, 12:42 AM
XtremeDime's Avatar
Default Turbo cams: VA Speed vs Speed Inc vs Brute Speed vs LS9?
Which one do you guys think for a turbo ls1(346)?
Virginia Speed VTC 2
23x-22x .610x-.60x, ?? LSA
Speed Inc TU1
223/225 .581/.581 113 LSA
Brute Speed FI cam
232/240 .595/.608 115 LSA
LS9 Cam
211/230 .562/.558 120 LSA
Old 09-15-2010, 06:23 AM
dschmittie1's Avatar
I think I would do either the VA speed or Speed inc cam as they are actually intended for Turbo cars. The Brute speed cam is more for Blowers and the ls9 cam just happens to do well on boost.
Old 09-15-2010, 07:12 AM
LS1Tech Sponsor
hellbents10's Avatar
With a MP T70 I would run the Speed Inc. grind.
Old 09-15-2010, 08:20 AM
Restricted User
98Z28CobraKiller's Avatar
You need to give more info. Atleast the size of the exhaust housing of the turbo. If you are using a single MP T70 with a 3" dp, I would for sure be looking at a reverse split like the VA Speed cam.
Old 09-15-2010, 08:30 AM
7 Second Club
Phil99vette's Avatar
I'd look for a reverse split and the va speed is on the only one that fits the bill.
Old 09-15-2010, 10:42 AM
XtremeDime's Avatar
Sorry guys. I have a Precision 76 GTS with 3.5" DP now. Exhaust housing is .81 a/r
Old 09-15-2010, 12:57 PM
Sluggish's Avatar
I just ordered a TU1 to try. I have been running a 239/233 but the car just doesn't run as well as it should.
Old 09-15-2010, 01:13 PM
XtremeDime's Avatar
What do you mean it doesnt run as well as it should? Are you expecting more power? Is the powerband in the wrong spot?
Old 09-15-2010, 01:19 PM
no title here
skyhighsami's Avatar
I vote custom grind. You don't buy one size fits all clothes so why buy a one size fits all cam?
Old 09-15-2010, 01:26 PM
XtremeDime's Avatar
I dont think my build is exotic enough to merit a custom cam? Its just a 76 on a stock ls1.
Old 09-15-2010, 01:50 PM
Frans96SS's Avatar
Agreed.
Old 09-15-2010, 01:52 PM
XtremeDime's Avatar
My only concern is that everything I had read about LSA and turbos is that it should be 114+ on a cam. Maybe 113 is close enough, lol
Old 09-15-2010, 02:05 PM
Sluggish's Avatar
The car has the stuff to run 9s @ 140. It doesn't seem to respond to changes in boost and timing. It probably isn't a can issue I'm just out of ideas. Next step will probably be a part out.
Old 09-15-2010, 11:57 PM
Hi Volume's Avatar
speed inc Tu1, its perfect.
Its not too agressive( IE 600+ lift) but just agressive enough. Valvetrain will be stable at its intended RPM range and easier to tune with, rather than a gnarley *** cam.
Just my $2 dollar bill
Old 09-16-2010, 01:07 AM
qqwqeqwrqwqtq's Avatar
TU1 has made over 900rwhp with a 76GTS on a 346.
Old 09-16-2010, 08:02 AM
engineermike's Avatar
Brute Speed FI cam
This is my favorite, followed by the TU1.
My own cam testing, as well as INTM8's, showed that reverse-splits don't work that well. I lost power going from a 224/236 to a 224/224. He gained power every time he added overlap. Both of these test results go against the "common logic" of turbo cam choice.
Old 09-16-2010, 08:38 AM
Restricted User
I'd still go reverse split on that.
Old 09-16-2010, 08:42 AM
Restricted User
You guys are making very generalized comments here. Every combo is different. You aren't even on an LSx platform. You are talking apples and watermelons here.
Old 09-16-2010, 08:49 AM
Sure, but people have been touting reverse-splits for LTx and SBC's for years, and they don't work that well on those. I don't see where the physics of the LSx is that much different (v-8, 2v, similar cid, similar pressure ratios).
I've never seen a back-to-back dyno test where a reverse-split gained power over a conventional split. I have seen the opposite.
Old 09-16-2010, 08:54 AM
Restricted User
I don't run a reverse split in mine nor am I saying that reverse split is the answer to all your turbo cam needs. But when you are running a small exhaust housing for the cubes, a reverse split is beneficial IMO.
Quick Reply: Turbo cams: VA Speed vs Speed Inc vs Brute Speed vs LS9?
